01-18-2006, 11:50 | #1 (permalink) |
Junior Member Join Date: Jan 2006
Member: 222309 Status: Offline Thanks Meter: 0 | SHARP GX30 USB Problem |
01-18-2006, 12:00 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Murcia,Spain Age: 45
Member: 116918 Status: Offline Sonork: 100.1590386 Thanks Meter: 559 | You need a COM port cable not the USB to unlock the phone using any software. But the USB drivers should install fine under windows XP that is what i have mine working on here just install the driver package and then after connect your phone to the cable and then switch it on the found new hardware wizard should appear and then you can install the drivers automaticly, if it dont work then it might be your drivers are bad i can send you mine by email if you want i have the disc here somewhere. |
01-18-2006, 12:34 | #3 (permalink) | |
Freak Poster Join Date: Jan 2005 Location: Nigeria Age: 54
Member: 107334 Status: Offline Thanks Meter: 10 | pls Quote:
most greatful (GOOD THINGS NEVER ENDS) | |
01-18-2006, 13:05 | #4 (permalink) |
Member: 116918 Status: Offline Sonork: 100.1590386 Thanks Meter: 559 | I have made up a package of stuff for the GX30i and am uploading now will post link here when finished about 20 minutes the pack includes. GX30i USB DRIVERS GX30i MODEM DRIVERS GX30i HANDSET MANAGER GX30i USER MANUAL GX30i UNLOCKER |
01-18-2006, 13:23 | #6 (permalink) |
Member: 116918 Status: Offline Sonork: 100.1590386 Thanks Meter: 559 | Heres your link http://rapidshare.de/files/11282184/GX30i.rar.html |
01-18-2006, 14:17 | #7 (permalink) |
Member: 222309 Status: Offline Thanks Meter: 0 | started downloading the file. will tell you how i go as i tried other downloads apart from my cd and still to no avail in xp.but since you said that it worked fine on yours...worth a shot...many thanks |
Looking for Sharp gx30 usb unloker...Please!! | mazzatore | Sharp | 4 | 06-22-2005 20:33 |
sharp gx30 usb cable pinout | SUPPERSTAR | Sharp | 1 | 03-19-2005 15:19 |
Need usb drivers for Sharp GX30 | bcnboy | Sharp | 14 | 10-16-2004 11:46 |
Need sharp gx30 usb data cable drivers | stukachu | Sharp | 2 | 08-07-2004 22:18 |
Sharp GX30 USB Driver | camomopa | Sharp | 1 | 07-09-2004 16:21 |
