Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sharp
Old 10-05-2005, 12:37   #1 (permalink)
Member: 161542
gx 25 unlocking
need to unlock sharp gx25,anyone can help?thanks.
Old 10-05-2005, 13:25   #2 (permalink)
SALNAI's Avatar
Member: 43478
Thanks Meter: 33
must have an USB cable and driver for win98 ,, for the soft you can try with RED-Box or SHARP unlocker from movilecom.org
best regards
Old 10-05-2005, 16:01   #3 (permalink)
Member: 91718
Thanks Meter: 10
If you have the cable, the software is here too http://www.unlockeasy.com/modules.ph...ownload&cid=38
BR.
The Following User Says Thank You to jmoreno2003 For This Useful Post:
Old 10-05-2005, 16:45   #4 (permalink)
BMobile's Avatar
Member: 154696
Thanks Meter: 16
Use Furious and choose GX15 + USB Cable. I unlocked 1 GX25 today.
PS: when click unlock , the screen will come black, don't worry, just remove battery and insert again, screen will show **** , and continue with unlock procedure to finish your work. Goodluck.
The Following User Says Thank You to BMobile For This Useful Post:
Old 10-10-2005, 13:48   #5 (permalink)
Member: 189005
Question bluetooth
I just got a SharpGX25 as a present but need to unlock it. I dont have a usb cable yet but i'm wondering if a bluetooth connection would work with furious?I'd rather get a bluetooth connection so that it will be compatible with other phones... not really sure how it works (which is prob obvious) and what the differences are between them. I've only used infared before to connect my old phone to my pc..
thanks,
Saz
Old 10-10-2005, 14:10   #6 (permalink)
Member: 161542
thank you all guys.everything okei.
Old 10-24-2005, 15:56   #7 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
thanks,
Saz
can i use unibox to unlock gx25 i dont have usb cable for gx25
The Following User Says Thank You to ricson For This Useful Post:
Old 10-24-2005, 17:40   #8 (permalink)
Member: 192666
Gx25
Hi ppl.
Same problem here I got a GX 25 and wanna unlock it...
Just a couple of questions...
Will it wipe the user data??
Also what about flah problems??
I'm new to this and by looking at the other threads it seems like a problem, but I really don't have a clue want they mean by it....
P.S. I'd like to know if I can remove the branding of "Vodafone" ....
Help!!!!
JAAS
Old 10-24-2005, 19:00   #9 (permalink)
SJS
SJS's Avatar
Member: 14684
Thanks Meter: 60
@ricson
Original data cable of nec e616 is exactly the same. And working sure!!
The Following User Says Thank You to SJS For This Useful Post:
Old 12-07-2005, 15:09   #10 (permalink)
Member: 147524
Just to confirm I have unlocked a Vodafone GX25 today as well with normal USB cable with Furious (select GX15). Make sure the battery is fully charged!
The Following User Says Thank You to gchui For This Useful Post:
Old 12-08-2005, 01:47   #11 (permalink)
karismajaya's Avatar
Member: 42805
Thanks Meter: 16
thanks for all...
the problem is solved
Old 03-09-2006, 12:21   #12 (permalink)
Abubakar's Avatar
Member: 73211
Thanks Meter: 5
I have original e616 usb cable i want to unlock my sharp gx25 pls what do i do
pls help its urgent
many thanx
Old 03-09-2006, 12:25   #13 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
you have to use "search" function of this forum
The Following User Says Thank You to Platijet For This Useful Post:
Old 03-09-2006, 13:30   #14 (permalink)
Abubakar's Avatar
Member: 73211
Thanks Meter: 5
pls i need i need to unlock my gx25 what do i do and do i need a driver to be able to unlock the phone
Old 03-09-2006, 13:32   #15 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
don't push me to close this thread.as i told you READ BEFORE ASK.
GX 25 Unlock Diag Needed dannyogolo Sharp 4 12-27-2006 07:28
About unlock Gx 25 via Bluetooth pentagono Sharp 9 03-23-2006 16:27
Sharp gx 25 dead after unlock Unlocker AL Sharp 25 09-26-2005 01:17
sharp gx 25 unlocker need BCcommunication Sharp 3 08-01-2005 12:54
GX 25 unlocker not working for me:( zoki Sharp 9 06-07-2005 01:01
Page generated in 0.21325 seconds with 9 queries
