12-16-2004, 04:13 | #303 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 45
Member: 4021 Status: Offline Thanks Meter: 782 | Quote:
TESTED 1000000000% WORKING!!!! EVERYBODY MUST TRY THIS!!!!! | |
12-16-2004, 13:18 | #305 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Here and there Age: 40
Member: 52560 Status: Offline Thanks Meter: 226 | I have read that is possible unlock sharp gx15 using BT. just selecting on sw the virtual comport set by bt. i have read that this has been tested. Has anybody tested it??? BR |
12-16-2004, 14:11 | #306 (permalink) | |
Junior Member Join Date: Dec 2004 Location: Don't know
Member: 97888 Status: Offline Thanks Meter: 0 | Quote:
12-17-2004, 02:20 | #307 (permalink) |
Junior Member Join Date: Nov 2004
Member: 93979 Status: Offline Thanks Meter: 0 | OK, here is the thing... I unlocked my phone with the BT following this directions: First, go to this link http://www.gsmspain.com/foros/showth...5&pagenumber=2 Create a Allsharp folder and download the following: * AllSharpARM.exe (476Kb) * InstallOCX.bat (24bytes) * InstallOCX.exe (11Kb) * PP.OCX (43Kb) * nec_sharp_reg.reg (14Kb) * MSCOMM32.OCX Now, lets do it: 1º. Open the Allsharp folder that we create. 2º. Run the "nec_sharp_reg" file that includes the software into the registry. 3º. Run the "InstallOCX.bat" file 4º. Copy the "MSCMM32.OCX" file into the C:/Windows/System folder 5º. Now run the "ALLSHARParm.exe" software 6º. A pop up window will open, just click OK and the program will run 7º. Activate the bluetooth in the sharp gx15. 8º. Exit the phone settings till we are in the main window 9º. Turn off the phone 10º. Remove the battery and the SIM card. 11º. Put the battery back, but not the SIM card 12º. Turn on the phone, the BT logo must be in the top of the phone. 13º. Open the BT in windows and follow this path: Quick Connect>Serial Port>(and the serial port number that we have on the phone, in my case it was the 8. Look for the phone in the connected apps 14º. Go to the All Sharp ARM window that we opened first (it must be behind all the windows we have) 15º. Select "Liberar GX15/GX30" (unlock GX15/GX30) 16º. Select, from the scroll menu "Serial USB Port" the port where we have the BT (in my case it was the 3). 17º. Select "Aplicar" (apply) in the Allsharp ARM 18º. The phone is now in unlocking mode (you will see that the phone is off and the screen onlyu shows 4*) 19º. In the Allsharp ARM window, there should be a code to follow, located in the left part of the software. (In my case, it goes like this: Press 1 Press 99 pulse the upper right key (in the phone) press 3 pulse the upper right key press 1 Now it will show "finished" in the screen, then press 3 times the upper right key 20º. Input the code in the phone, as you press the first number, the phone lights up That's it, if we do this steps right, the phone is now unlocked I did it, and as I unlocked it, I try 3 different SIM cards, from 3 companies, and it worked with all of them Good luck to all, and if you have any problems, just let me know I have the software, so if you can't get it from the link I gave, just ask for it, and I'll send it |
12-17-2004, 02:21 | #308 (permalink) | |
Member: 93979 Status: Offline Thanks Meter: 0 | Quote:
Sorry, but spanish is my native language, that's why I post the instructions in english Good luck | |
12-17-2004, 16:46 | #310 (permalink) | |
If so how? Last edited by hood_mir; 12-17-2004 at 18:34. | |
12-20-2004, 22:48 | #312 (permalink) |
No Life Poster Join Date: May 2002 Location: distant galaxy Age: 50
Member: 12386 Status: Offline Thanks Meter: 18 | need help for sharp programme hi all, i have been using this sharp unlocking software for a time without any problem until today.today i got this message when i tried to run the software. your system clock appears to have been set back possibly in an attempt to defeat the security system on this program. please correct your system clock before trying run this program again. if your clocks correct, please contact the author of this program for instruction on correcting this error.report-code(CCB-TT). can someone please tell me what to do i tried to reinstall the software again still get that message. thanks jab |
12-21-2004, 01:24 | #314 (permalink) | |
Freak Poster Join Date: Apr 2003 Location: UK
Member: 27106 Status: Offline Thanks Meter: 0 | gx10i o2 settings Quote:
*** HOW TO Buy 5,10,15,20,25,50 or 100 SMTi Credits for 1 minute 24/7/365 *** | gsminfo | SMTi | 16 | 12-20-2010 12:06 |
sharp unlock gx15,20,25,30 free download free | ronelmale | Sharp | 1 | 09-12-2005 08:46 |
Test This Gx15/20/30 Free Unlock | ALIN | Sharp | 9 | 09-28-2004 09:29 |
