VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800. VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508. Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208. Skyworks: A500, C100, C108, C110, P510, P518. |
07-03-2002, 12:49 | #2 (permalink) |
Junior Member Join Date: May 2002 Location: Ukraine Age: 50
Member: 11539 Status: Offline Thanks Meter: 0 | When I short 4-5 pin phone say me NACK recieved Elapsed time: 0.1s C:a300\ C:a300\ C:a300\ C:a300\ When I solder this pin with 74hc14 1 and 6 pin phone display me Timeout waiting ACK ( phone power on and charging) Anybody have tested box from ABE? |
07-03-2002, 13:53 | #4 (permalink) |
Member: 11539 Status: Offline Thanks Meter: 0 | When I reconnect 6pin 74hc14 on 2pin phone (no power on) and : ¦ Sharp, Atmel, Fujitsu FlashRom AutoDetection ¦ 09:50 ¦ FlashRom H/W Protection Version (Board 4.1) ¦ ¦ English & China OGM Integration Version ¦ ¦ Copyright(C) 1996-2000, SAMSUNG ELECTRONICS ¦ +-----------------------------------------------+ Downloading : Main + OGM Serial Port : COM 1 Main File gn30aug1.axf : size 1935 KB (0x1E3B68) OGM File gn30aug1.ogm : size 729 KB (0xB61FC) Transfer Initialization NACK received Elapsed time: 0.1s D:\run\samsung\a300> D:\run\samsung\a300> D:\run\samsung\a300> D:\run\samsung\a300> |
07-04-2002, 21:58 | #7 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Vietnam Age: 57
Member: 13356 Status: Offline Thanks Meter: 2 | NACK RECIEVED Hi - u can use schematic a300 cable on www.gsmhacking.com it OK - but i think your PC have problem ! ( before 3 month i have the same problem ) now u try : - run flash program ( not connect cable and phone to PC) if sofware say " time out ....." your PC no problem , now connect cable and phone and run again , if still say " time out ..." you must change to another PC ( lower speed PC ,or laptop PC ) - if software say " NACK RECIVED ... " ( not connect cable and phone ) - your PC have problem in comport . now on your PC entry : system properties - device manager - port - com1 ( enter properties ) mask ( disable in hard ware ) - ok , after that unmask ( disable in hard ware) - ok --- now comport 1 ok - run flash software u will see " time out .... " now connect cable and phone to PC and try . good luck! |
07-05-2002, 13:24 | #9 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Hong Kong
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | Hello For first the tool box can not work for A300 (Conexan ARM7) and for the problem it seems it's your computer's UART problem , so far only IBM computers can 100% stable to rum axx series program. |
samsung a300 flash problem | cs55 | VLSI, Conexant, Skyworks and Old Models | 7 | 12-08-2002 13:56 |
a300 flash other language | NNN | VLSI, Conexant, Skyworks and Old Models | 0 | 03-27-2002 05:50 |
A300 flash | pornopig | VLSI, Conexant, Skyworks and Old Models | 2 | 03-20-2002 13:59 |
Samsung A300 flash reading | billgate | VLSI, Conexant, Skyworks and Old Models | 1 | 11-21-2001 12:10 |
Samsung N200/A300 flash cable free for all!! | winers | VLSI, Conexant, Skyworks and Old Models | 15 | 10-08-2001 18:45 |
