VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800. VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508. Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208. Skyworks: A500, C100, C108, C110, P510, P518. |
09-03-2003, 22:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Africa
Member: 8843 Status: Offline Thanks Meter: 117 | A800 Killed By Full Reset Help! PLEASE HELP!! |
09-04-2003, 00:12 | #7 (permalink) |
Member: 8843 Status: Offline Thanks Meter: 117 | i got the programme SGH-A800 Protect Stack and flash file A80xavk3. chose Baud-115200, binary+ogm. opened files, option checked file name and checksums i then connected the cable & pressed START. nothing seems to be happening. It says DOWNLOAD STATUS and nothing is moving. Is it because i am using the A300 unlocking cable? WHAT AM I DOING WRONG? |
09-04-2003, 00:59 | #8 (permalink) |
No Life Poster Join Date: Sep 2000 Location: UK York Age: 56
Member: 2008 Status: Offline Thanks Meter: 4 | Hi Use T100 Cable and uncheck the three options checksum, continous, filename. and click the option at the top for Binery+Ogm and set the speed to 115200 and away you go and everything will be fine my friend. regards Charlie |
09-04-2003, 23:01 | #10 (permalink) |
Registered User Join Date: Sep 2002
Member: 15866 Status: Offline Thanks Meter: 192 | USE FLASHER 4.3.2 AND FLASH FILE AND USE T100 CABLE AND WHEN U WILL CONNECT UR MOBILE WITH CABLE RED LIGHT WILL BLINK OF PHNE THE WLL INDICATE THAT CONNECTION ESTABLISH THEN START FLASHING |
09-05-2003, 21:03 | #14 (permalink) |
Member: 8843 Status: Offline Thanks Meter: 117 | k thanx for the infor am now looking for the T100 cable. This is what i have done so far:- Am using Windows ME i don't know if it works with this, i have used the A300 unlock cable & also modified another unlock cable to be a flasher cable like the pinout from BRUCE's PINOUT.i used A300 unlock cable pinout: 1,5,18 ---- VPP 11 ---- GND 17 ---- TX 16 ---- RX 15 ---- DATA OUT 14 ---- DATA IN i then modified it to be like a T100 as per BRUCE's PINOUT 7 ---- VPP 11 ---- GND 17 ---- TX 16 ---- RX 15 ---- DATA OUT 14 ---- DATA IN If i can't get the T100 cable, is the above correct? Also which windows should i use? How exactly should i flash? HEEEEEELPPPPPPPPP! |
09-05-2003, 21:35 | #15 (permalink) |
No Life Poster Join Date: Mar 2003
Member: 24435 Status: Offline Thanks Meter: 4 | have same problem ..go to www.gengheraenga.net get flash reflash phone and it work agein...exactly same problem.. |
6630 killed by UB - Need help to recover | JezH | Universalbox | 4 | 11-06-2009 19:16 |
6103 killed by UB doing Full Factory | nikkomusa | Universalbox | 1 | 12-15-2007 14:16 |
How To Revive V980 Killed By Mss4?please Help! | KUBAT1 | Motorola P2K (USB-Smart) | 13 | 03-21-2006 16:54 |
V60 killed by SmartMoto, please help. | cubafreak | Smart-Clip | 1 | 02-03-2006 17:56 |
twister killed by vigis... any help ? | dghersin | Twisterflasher | 4 | 08-16-2005 21:55 |
