VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800. VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508. Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208. Skyworks: A500, C100, C108, C110, P510, P518. |
03-26-2002, 22:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: on the beach
Member: 4160 Status: Offline Thanks Meter: 2 | How unlock A300/400 ? I've 1 A300 and 1 a400 to unlock ,i've tried with Santel but nothing!! Could you help me please with a sw,i've the good cable with extern power? best regards Evilspell |
03-26-2002, 22:25 | #2 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Karabakh - Azeris motherland Age: 45
Member: 9856 Status: Offline Thanks Meter: 2 | Use Pajo! Hi I also had one A300 with simlock. I read eeprom with pony then used Pajo v3.6. It works, very good software (thanks Pajo)! BufferMess |
03-27-2002, 06:24 | #5 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Edinburgh UK
Member: 7958 Status: Offline Thanks Meter: 6 | take the eeprom off...........carefully...watch pad 6 read it using pony prog.....25256 16bit eeprom...api interface. make sure voltage is set to 3v..NO MORE edit buffer enabled change bit 822 to 00 replace eeprom. if langauge comes up in german..the phone's not reading the eeprom..check solder.i you fryed eeprom use one from a 3210.half the size but works fine. FXXK buying a box for £100 when a £3 lead is all thats needed. regards, |
03-27-2002, 06:59 | #6 (permalink) |
Member: 4160 Status: Offline Thanks Meter: 2 | Hi, Thanks Badnes5 for your good explanation!! but i cannot do it ,because it's not mine and the *******r don't want to open it!! i need a "unlock" by cable sw , i know where i can buy it but for 3/4 pieces,it's not interesting. If i have 20/30 pieces the problem is simple :to buy the box,but it's not the case. Anyway ,thanks for your help best regards Evilspell |
04-11-2002, 06:11 | #8 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Hong Kong, China
Member: 7866 Status: Offline Thanks Meter: 4 | Hi, I think some people can do it for you in your country, just charge you US 2 to 5 dollars !!! Or you can build a i2c cable and read the EEprom by PONY then using the Pajo software to read the code !!! Cables [email protected] Last edited by Cables; 04-11-2002 at 06:13. |
04-11-2002, 07:23 | #10 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Africa
Member: 8843 Status: Offline Thanks Meter: 117 | @ Zzzooommm how is that possible and do u have the software coz some of usn have been using PonyProg. if u could tell us the link to this MS-DOS flasher soft or drop one in my inboxhere regards |
04-11-2002, 08:07 | #11 (permalink) |
Member: 7866 Status: Offline Thanks Meter: 4 | I can tell you that after flashing the SP lock still remain, but some old firmwares (flashes) for A100, M100, A300, A400 allow you to check the ME Lock code by the keypad method *#9998 ........... , (or calculator from IMEI). The question is, the new version of Samsung phones have been disabled this 'Tricks' and the new phone cannot be power on after flashed with an older firmware (or caused sector locked). I am 100% sure you cannot remove the SP lock by just flashing the phone !!!! Cables [email protected] |
05-04-2002, 23:01 | #12 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Palestine Age: 61
Member: 9763 Status: Offline Sonork: 100.1655983 Thanks Meter: 2 | Hi Cables & all Guys I did a mistake flashing A300 with old firmware I got from www.huier.net , and now the phone sector locked ,I can't flash it again with a new good flash I got Error 03 , please help me what can I do ? BR Laser |
how unlock a300 and reset securiy code? | galsch | VLSI, Conexant, Skyworks and Old Models | 1 | 10-01-2003 13:12 |
How Unlock A300 with ChineseBox? | mourad_t | VLSI, Conexant, Skyworks and Old Models | 7 | 07-17-2003 09:48 |
How unlock A300? | Toucher | VLSI, Conexant, Skyworks and Old Models | 2 | 09-08-2002 03:18 |
How unlock A300 & N100? | Migeni | VLSI, Conexant, Skyworks and Old Models | 1 | 08-11-2002 20:06 |
Samsung A300/400 unlocking clip cheap!!!!!!! | heartcomms | Main Sales Section | 8 | 02-03-2002 22:02 |
