VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800. VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508. Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208. Skyworks: A500, C100, C108, C110, P510, P518. |
09-29-2003, 13:59 | #10 (permalink) | |
No Life Poster Join Date: Feb 2002 Location: UK
Member: 9732 Status: Offline Thanks Meter: 27 | Re: repairer system failure n620-t100 Quote:
10-07-2003, 02:07 | #14 (permalink) |
Crazy Poster Join Date: Jan 2002 Location: xxxx
Member: 8781 Status: Offline Thanks Meter: 1 | HI Guys i had the same problem i tryed everying there is to solive the SYSTEM FAILURE problem i buyed pone programe i used all the softwear you can find this is how it works if you want to solive the problem 1-check charging conector that is at the end of the phone (take it off totely if you dont know what to do) clean it well 2 or 3 times resolder it back try resoldering all the small parts that r neer the charging jack IF THAT DOSENT WORK 2-the best programe that is 100% working with all phones better then any programe you will very find Very eusy to use for ALL Samsung phones UST Pro pepole will say that its not for free 300$ is nothing for what this programe can do .More then that VSH gives you full support (Free)with all the leatest flash files for all old and new samsung Phone I stoped looking for Samsung programs when i started useing it it unlock it flashed if ------(Fixs SYSTEM FALIURE)------ For ALL Phones is 300$ to much FOR All of this i think NO |
10-08-2003, 20:34 | #15 (permalink) |
No Life Poster Join Date: Mar 2003 Location: USA
Member: 23534 Status: Offline Thanks Meter: 17 | new way hello to mr adel (xxboxxx) how are you guys i try to slove the same problem in n 620 but he didnt respond but after i tierde to fix it i but all the small ic down again and i try the phone >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> i did it the phone fix all waht i've do is remove and replace the 2 ics>>>>>>>>>>>>>> i think u have to try evry think b.r iyass |
system failure n620 | yapson1 | Samsung Hardware Repair | 0 | 07-22-2009 20:09 |
A problem with N620 ,N620E after repairing System Failur | GSM SNIPER | Samsung Hardware Repair | 5 | 09-13-2005 02:16 |
need repair systeme failur | oranais | VLSI, Conexant, Skyworks and Old Models | 12 | 05-25-2004 21:26 |
ust 5.4 not working to repair system failure when i write eeprom | tcteam | Samsung Flashers, Software, Firmware. | 1 | 02-04-2004 23:10 |
Repair system failure on N600 | cpu486 | VLSI, Conexant, Skyworks and Old Models | 2 | 09-23-2003 14:46 |
