VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800. VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508. Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208. Skyworks: A500, C100, C108, C110, P510, P518. |
10-09-2003, 20:22 | #19 (permalink) |
Freak Poster Join Date: Jun 2002 Location: Russia Age: 47
Member: 13257 Status: Offline Thanks Meter: 1 | anyone can send me this solution??? Please!!!! [email protected] 10x!! |
10-09-2003, 21:23 | #20 (permalink) |
No Life Poster Join Date: May 2002 Location: asia Age: 54
Member: 11742 Status: Offline Thanks Meter: 1 | hi all cs problem in T100 [if any soft does not work] then it is 100% hard ware. just try this,,,,, on the upper side of eeprom and near the edge of cpu ,u will find a 'chip resistor ' just resold it with fine tipped iron,if still does not solve ,then remove eeprom [specialy for dropped fones]and check the print on eeprom,often soldering pads on eeprom were found broken.scratch the green silicon paint on copper tracks and solder thin wires and fix it to board. if u recive a fone ,water damaged or humidity effected,check the small caps near charging connectors,these are found short ususaly,just remove them to check cs problem solved or not ,and afterwords u can solder them again. chip resisters in N620 r located ,just below and on the left side of eeprom. clean charging connector thorougly with spirit or rust remover,in water dameged fones ,u will see green colour oxide in the charging connector ,clean it completly. when u will got familiar with chip resisters, eeproms ,u can locate these on other models ur self. thanks. |
10-12-2003, 22:35 | #24 (permalink) |
Insane Poster Join Date: Oct 2003 Location: SOUTH INDIA Age: 51
Member: 40770 Status: Offline Sonork: 100.1575894 Thanks Meter: 10 | hi guys that link can get in ENGLISH language....? any links to know more of UST PRO? I AM USING sgh jig box 60% PCS OK,REST OF THE PCS GIVING ERROR AFTER WRTING EEPROM "verification failed n 000h" |
11-03-2003, 20:04 | #26 (permalink) | |
No Life Poster Join Date: Dec 2001 Location: [☾✫ ] Age: 58
Member: 8159 Status: Offline Thanks Meter: 98 | Re: repairer system failure n620-t100 Quote:
http://www.ombossmangsm.com/freefree/sytemfailure.jpg http://www.ombossmangsm.com/freefree/sytemfailure2.jpg your page very hard registered | |
system failure n620 | yapson1 | Samsung Hardware Repair | 0 | 07-22-2009 20:09 |
A problem with N620 ,N620E after repairing System Failur | GSM SNIPER | Samsung Hardware Repair | 5 | 09-13-2005 02:16 |
need repair systeme failur | oranais | VLSI, Conexant, Skyworks and Old Models | 12 | 05-25-2004 21:26 |
ust 5.4 not working to repair system failure when i write eeprom | tcteam | Samsung Flashers, Software, Firmware. | 1 | 02-04-2004 23:10 |
Repair system failure on N600 | cpu486 | VLSI, Conexant, Skyworks and Old Models | 2 | 09-23-2003 14:46 |
