Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900. |
05-20-2008, 12:44 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: i dont know. where i am Age: 35
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | how to unlock samsung m110. but not unlock sucess. here is ustpro2 log.pls help me how to unlock it. Reading data from box... Power ON phone... Phone detected! Setting sysol test mode... thanks to everybody |
05-20-2008, 18:04 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Patch unlock = non pro
Member: 323137 Status: Offline Thanks Meter: 235 | It can be done by code i have done it on 2 samsung sgh-M110 The imei stayed the same on the 2 phones. Take a non-accepted sim card. Put half of it in the phone start the phone. When you see insert sim put in all of the card. Press the code *2767*3855# now the phone restart and you should come to the menus. check what lock is active by presing*#7465625# the phones i unlocked had subset and network locked if it's the same on yours then use this code. type *7465625*782*00000000*00000000# and after type #7465625*782*00000000# now subset lock should be unlocked. type *7465625*638*00000000*00000000# and after type #7465625*638*00000000# now the network lock should be unlocked. Turn of the phone and try if the phone is sucessfully unlocked. Subset must be unlocked first it will not work if you take network lock first. |
The Following 6 Users Say Thank You to reactos For This Useful Post: |
06-08-2008, 15:46 | #3 (permalink) | |
Junior Member Join Date: Jun 2008
Member: 789284 Status: Offline Thanks Meter: 0 | Worked for me Quote:
Many thanks | |
06-08-2008, 23:39 | #4 (permalink) |
Member: 789284 Status: Offline Thanks Meter: 0 | Posted too soon. Although I can use the M110 with a UK PAYG T-Mobile SIM, I have a problem when I try a Spanish PAYG Vodafone SIM. It is asking for the password (which I do not know) Is there a way to stop the phone asking for the password/PIN Thanks M110User |
11-13-2009, 18:37 | #6 (permalink) | |
Junior Member Join Date: May 2005 Age: 44
Member: 143845 Status: Offline Thanks Meter: 2 | Quote:
08-04-2010, 16:20 | #7 (permalink) | |
Insane Poster Join Date: Jun 2009
Member: 1059105 Status: Offline Thanks Meter: 15 | Quote:
03-10-2017, 05:15 | #8 (permalink) | |
Freak Poster Join Date: Mar 2015 Location: Nairobi
Member: 2358876 Status: Offline Thanks Meter: 78 | THIS PERMANENTLY WORKED By Sir Real 1000% Quote:
I Modified your procedure and found this to be PERMANENTLY UNLOCKED THE PHONE. -No Box -No cable -internet -JUST a working TECHNICAL BRAIN SGH-M110-----UNLOCK TEMPO __________________________________________________ _______________________ PROCEDURE--TEMPORARY -Use one Finger to hold battery Above SIM SLOT - Insert SIM card Half way - Turn ON phone - it will say INSERT SIM, push the simcard IN -Dial*2767*2878# now it should restart and work with your sim card. MENU WILL SHOW AND PHONE WORK---(This is TEMPORARY) +++++++++++++++++++++++++++++++++++++++++++++ DO THIS AFTERWARD TO PERMANENTLY REMOVE THE NETWORK UNLOCK This will only work AFETR DOING THE FIRST PROCEDURES ABOVE) __________________________________________________ _____________________ SUBNET LOCK & NETWORK UNLOCK DIAL *7465625*638*00000000*00000000# DIAL *7465625*782*00000000*00000000# AFTER THAT DIAL #7465625*782*00000000# AFTER THAT DIAL #7465625*638*00000000# now subset lock should be unlocked now network lock should be UNLOCKED VIOLA EVERYTHING IS PERMANENT NOW 10000.....Tested by Sir Real | |
How to unlock Samsung E900 ? Direct Unlock dont work | MisterX GSMFREE | HWK | 6 | 08-03-2010 17:31 |
Here is how to unlock Samsung M110 | ZoHaiB_(FoneGSM) | Easy-Unlocker | 7 | 07-06-2008 11:01 |
how to unlock samsung A727 and what cable to use?? | tsarkh | Rocker Dongle (By Legija) | 6 | 07-02-2008 19:59 |
how to unlock samsung-n100 simlock code? | Siemens man | VLSI, Conexant, Skyworks and Old Models | 4 | 11-11-2001 10:09 |
How to unlock Samsung SGH-R320 | vakaras | VLSI, Conexant, Skyworks and Old Models | 0 | 09-20-2001 13:10 |
