SYSOL Platform S500, S508, D488, E100, E330, E335, E338, E630, E635, E638, E700, E708, E800, E808, E820, P300, X100, X108, X460, X468, X490, X495, X600, X608, X620, X628, X640. |
09-01-2004, 09:45 | #1 (permalink) |
Junior Member Join Date: Sep 2004 Age: 39
Member: 80127 Status: Offline Thanks Meter: 0 | e700 Corrupt Java Delete Problem Cannot Access SkateSlam Exception: java.lang.NumberFormatException: null And there is no option to delete the game. I have tried EVERYTHING i can think of, i have did a settings reset, a full EEPROM reset (#*7337#), even tried the java reset code (*2767*5282#) but this code didn't seem to do anything. Is there ANY way i can get rid of this corrupted game, either by finding some way to manually delete a section of the java memory (as it seems to be seperate from the rest of the phones memory as it doesnt get wiped with #*7337#) or if any people out there know how to create a "dummy game" that maybe had a newer version number and was actually just a blank dummy jar/jad file and allowed me to overwrite the existing Skate&Slam entry in my downloads and then delete it as normal, or if anyone out there has any other ideas as to how to do it? I would REALLY appreciate your help with this. Thanks. Mark Mckim |
09-01-2004, 10:41 | #3 (permalink) |
Member: 80127 Status: Offline Thanks Meter: 0 | hey thanks for replying. Sorry but im a COMPLETE beginner at this so would you be able to explain what you meant in your last post. 1) I have IR on my computer, is it possible to fix using that or do i need a cable? 2) Will this erase EVERYTHING on my phone or just the java section? 3) Will this DEF erase the java section as the full eeprom erase didnt affect the java downloads? 4) Is this easy to do? 5) Is this installing a new firmware on my fone? 6) My software version is currently E70AYWK2, do i need to install another version or the same version just overwriting the existing one? 7) Is this process dangerous? 8) Where can i get the necessary kit and firmware and software? Sorry for so many questions but your help is GREATLY appreciated on this, thanks for your patience. Mark |
09-01-2004, 11:09 | #4 (permalink) |
Registered User Join Date: May 2004 Location: south africa Age: 41
Member: 66075 Status: Offline Thanks Meter: 2 | ok , u need a flasher cable first then download any original firmware then download ' downloader 3.3 ' from there on it should be pretty you cannot 'ir' because ir only work when the phone is on if you dont have a flasher cable the i suggest you go out and buy one it must say specificly e700 or e708 flash cable phone need to be fully charged when doing this process and it need to be off |
09-05-2004, 23:50 | #5 (permalink) |
Major Poster Join Date: Aug 2004 Age: 44
Member: 79378 Status: Offline Thanks Meter: 0 | get a copy of the problem .jar -download a real simple small midlet from the likes of 'midlet.org' -rename the .jar file extention to .zip and extract as usual. -go to the manifest file and open in 'Notepad' -change the details of the of the 'simple' midlet name and vendor to the problem one. -change the midlet version to later number. -select the extracted files again and zip back up -rename back to .jar -get copy of .jad wizard program to create new jad file http://www.tatool.piwko.pl/down/gsm.html IMPORTANT: it has to say newer version, ok to overwrite!! do not download otherwise |
X701 data delete problem ?????? | Littlemaster | Infinity-Box | 7 | 02-07-2007 06:29 |
E700 no java folder where to upload games pls help | codec_romania | SYSOL Platform | 0 | 04-22-2005 14:54 |
Need Samsung SGH-e700 free java games polyphone melodies , wallpaper , screensavers | |COBRA| | Java, iOS, Android, Symbian development | 2 | 06-05-2004 04:04 |
P800 2x pic corrupt cant delete help | snoopycellular | Sony Ericsson | 1 | 05-30-2004 00:09 |
samsung e700 compatible java | welly_59 | Java, iOS, Android, Symbian development | 1 | 11-25-2003 12:48 |
