Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > SYSOL Platform
SYSOL Platform S500, S508, D488, E100, E330, E335, E338, E630, E635, E638, E700, E708, E800, E808, E820, P300, X100, X108, X460, X468, X490, X495, X600, X608, X620, X628, X640.
Old 07-12-2006, 21:59   #1 (permalink)
Member: 310562
Thanks Meter: 2
Unhappy Really Need Help With Dead E800 - Maybe Easy?
Hi.
Acquired E800 having problems booting and when it did it had real problems with any kind of animation (menu wouldn't show, start-up screen not animated). Managed to connect with data cable and found loads of files and SMS on there. Deleted the lot (thinking phone suffering from lack of available memory). No improvement.
Decided to flash phone, so used serial flash cable and "SGH-E800 Downloader v1.75beta" to download flash file E800XADG1. No improvement.
Decided to make fresh start and erased the phone. DOH! STUPID! Program screwed up and disconnected from phone. Now I can't power it on so the program can't find the phone, so now I can't reflash the BIN. file to at least get it working again.
Bugger.
Can anyone help? Please? Even some idea as to what i could do?
Old 07-13-2006, 23:55   #2 (permalink)
Member: 213731
*2767*3855# = E2P Full Reset
thats all u had to do to reset the fone to get the animations!!
not sure wat uve done to it tho
Old 08-13-2006, 12:10   #3 (permalink)
Member: 163397
Thanks Meter: 3
you must specify witch box are using to flash thre fone ?
Old 09-08-2006, 22:55   #4 (permalink)
Member: 310562
Thanks Meter: 2
Sorted it. The phone switched on again after I'd left it for a bit. Managed to flash it properly. However, discovered original problem was caused by main board flexi ribbon. Replacing that sorted it out (be careful with the black flexi ribbon connector clip - fiddly, weak little buggers).
[IMG] code is Off
Please I need Help with nokia 7373 maybe software Fred_SLAM Nokia Base Band 5 ( BB-5 ) 4 09-01-2008 08:52
I really need help with the eeprom hurdles Motorola P2k 1 10-05-2004 13:31
really need help with bad flashed 3510 Blartiartfast UFS2 + UFS3-Tornadoflasher 0 03-15-2004 00:20
need help with c55 unlock?maybe freeman can help sincere Phone Unlocking Codes & Maps 24 10-21-2003 16:55
Really need help-T200 dead after 10 days T200 VLSI, Conexant, Skyworks and Old Models 0 05-25-2003 20:34
Page generated in 0.12175 seconds with 9 queries
