SYSOL Platform S500, S508, D488, E100, E330, E335, E338, E630, E635, E638, E700, E708, E800, E808, E820, P300, X100, X108, X460, X468, X490, X495, X600, X608, X620, X628, X640. |
11-07-2004, 13:03 | #1 (permalink) |
No Life Poster Join Date: Dec 2001
Member: 8102 Status: Offline Thanks Meter: 118 | Samsung Experts Help Needed on semi-dead E800 !! Anybody any ideas please ? |
11-07-2004, 20:52 | #2 (permalink) | |
Insane Poster Join Date: Sep 2004 Location: wales uk Age: 64
Member: 81960 Status: Offline Thanks Meter: 0 | Quote:
u say it is brand new if it is clean (( not nicked )) samsung repair it for free as long that u did not play with it like unlock or flashing ?? if it is not clean take the cover off clean the keys pad and close it up it should work it is like any pad the contact lose if it is wet hope that help in any way | |
11-08-2004, 09:12 | #4 (permalink) |
Freak Poster Join Date: Jun 2003 Location: LZ - Bulgaria
Member: 30940 Status: Offline Thanks Meter: 13 | this happen when phone recognize one(or more) constantly pressed key you can easy try with other working phone-press and hold any key and then switch ON phone check volume and camera keys also on keypad check carefuly static discharge pads on every key to GND hope that this can help - in other way maybe worst - failure CPU this can check if you measure resistance (in both ways) of any keypad to GND - if you see big difference in any measurement - this is not good and at least this can be software problem , but it is very doubtfull... |
11-27-2004, 21:58 | #6 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Lagos Nigeria
Member: 61176 Status: Offline Sonork: 100.86572 Thanks Meter: 368 | a minor error but a great income for me.... it happen almost everyday here and to the Glory Of Him, i am the only person that knows the solution around here... and so.... you know.........i charge whatever i feel like...i would like say what i do to them here, the same as full network but difficult to make a call... but my next door neighbours might be here... what if they do.... you know what it means for me....? solution available only on PM |
04-01-2005, 16:20 | #9 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: nigeria
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | Na Today????? Quote:
BLA BLA BLA BLAH...................... | |
04-06-2005, 00:52 | #10 (permalink) | |
Member: 61176 Status: Offline Sonork: 100.86572 Thanks Meter: 368 | your E800 solution Quote:
this is a twin pcb phone that has a flex as the link between the two phones, once this flex is bad, the phone could misbehave in various ways, the only solution to this phone is change the flex which is very much available in the market and cheap too and the phone is parfect again. the flex is easy to change too but pay attention to the clip as it's easily damaged. once you change the flex, the phone will be as good as new! for other samsung models, no need to remove diodes, just disassemble the phone, remove inner keypad and the pcd is now *****, get fuel that is still ice when felt(petrol u use for your car) and do not allow it to ventilate, put the pcb ib it, allow for about 10 minutes then rinse with soft (tooth) bruch, put under sun for some minutes and phone perfect again.. tested 100% on X450, E318, X100, X600 and the other solution tested on my E800 enjoy! Regards from Nigeria | |
04-06-2005, 01:26 | #11 (permalink) | |
Member: 61176 Status: Offline Sonork: 100.86572 Thanks Meter: 368 | Quote:
i like meeting people like you, they only make me a better person, they will offend me for no reason but i will try forgive them and it beeters my ability to forgive and this helps make me able to forgive all offences and because of this, i never had problems with anybody! thanks for your offence, it added a quality to my life and that quality attracts meaningful and profitable friends to me! G.O.D Of Nigeria (Hasha bunna) Bless you Last edited by magixian; 04-06-2005 at 01:59. | |
<<< SAMSUNG EXPERT HELP WANTED! SAMSUNG U600 (?) Please look at the picture: >>> | Mr.Ultimate | Samsung Hardware Repair | 22 | 12-01-2009 21:31 |
Experts help needed!!! | mobilelink | Nokia Hardware & Hardware Repair | 0 | 08-08-2007 08:39 |
Help Needed On Samsung D500 | TWISTED ONE | SWIFT Platform | 4 | 09-06-2005 03:02 |
ReAL ExPeRtS help needed ... c55 powering off itself | Brka | Siemens Hardware Repair Area | 13 | 07-07-2004 11:22 |
Help needed on Be-1 dead phones | chray | Alcatel & TCL Old Models | 0 | 01-20-2002 18:13 |
