Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
12-21-2005, 21:28 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: south Afrika Age: 38
Member: 15156 Status: Offline Thanks Meter: 73 | d600 imei change problem with sus |
12-22-2005, 11:01 | #4 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 45
Member: 55631 Status: Offline Thanks Meter: 55 | Quote:
If you still have the same problem then perform a full reset... (*2767*3855#) NOTE: Latest SUS is 051218. | |
12-22-2005, 15:45 | #5 (permalink) |
No Life Poster Join Date: Nov 2004 Location: In a Ganja plant! Age: 38
Member: 91298 Status: Offline Thanks Meter: 6 | I have done the same and had the same problem If you go to band selection (under network settings) change it to 900/1800 (it will be set to "Tri Band") then your problem is solved. |
imei change problem with V3r,V360v and V360. | Miangee911 | Ultima Box Light | 11 | 09-29-2007 09:41 |
s 400i imei change problem with ustpro2 | tekila1975 | UST Pro II | 3 | 03-26-2007 14:54 |
