Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
01-25-2019, 10:08 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Worldwide
Member: 2174901 Status: Offline Sonork: 100.1671257 Thanks Meter: 1,248 | Fix Binaries Are Mixed Up!! For New Samsung Devices Sometimes when you flash the phone you have problem with Fix Binaries Are Mixed Up!! 0 0 0 0 and the phone can't enter to download or recovery or even to boot. However, today our topic to solve this problem only you need (press Bixby And -Vol with USB Cable only) (Without press power button) And the phone goes to download Mode now flash 4 files Done Halabtech-Team |
The Following 11 Users Say Thank You to hosam kashto For This Useful Post: |
01-26-2019, 13:16 | #2 (permalink) | |
Freak Poster Join Date: May 2012 Location: Haiti, Port-Au-Prince, Carref.
Member: 1763284 Status: Offline Thanks Meter: 56 | Quote:
Sent from my Nexus 6P using Tapatalk | |
The Following User Says Thank You to Castle2k For This Useful Post: |
01-27-2019, 23:56 | #3 (permalink) | |
Freak Poster Join Date: May 2017 Location: USA
Member: 2718897 Status: Offline Thanks Meter: 49 | Quote:
Sent from my SM-N960U1 using Tapatalk | |
04-21-2019, 17:17 | #4 (permalink) |
No Life Poster Join Date: May 2002 Location: TX Age: 49
Member: 12427 Status: Offline Thanks Meter: 78 | I have S9 G960U with Binaries are mixed up!! : 00008 Can enter download mode fine with normal buttons pressed, and flash successfully but still getting the same error. Flashed com file G960USQU4ASC1 phone boot ok Flashed stock G960USQS4CSC3 or G960USQS4CSC8 successfully but getting the error |
05-05-2019, 01:53 | #5 (permalink) | |
the "00008" you see indicates the binaries.. you have one bibary that is mismatched (the 8 at the end means its different than the others) The partitions that are checked for binary mismatch are: abl boot system vendor odm if those 5 binaries are from same firmware you will not get a mismatch. of course you might have other errors if other binaries dont match such as those 5 from stock and tz/pmic from combo it might not boot up etc etc Sent from my Pixel 3 XL using Tapatalk | |
The Following User Says Thank You to elliwigy For This Useful Post: |
09-06-2019, 22:59 | #6 (permalink) |
Freak Poster Join Date: Sep 2012 Location: south africa Age: 39
Member: 1813139 Status: Offline Thanks Meter: 45 | Hi thanks bro its works i was wondering so much but i was doing a mistake i use charger for the power source but its need cable should be connect in computer thanks again |
01-25-2020, 22:37 | #8 (permalink) | |
Insane Poster Join Date: Mar 2010
Member: 1249625 Status: Offline Thanks Meter: 17 | Quote:
11-13-2020, 08:34 | #9 (permalink) |
Insane Poster Join Date: Sep 2016 Location: Peshawar, Pakistan Age: 40
Member: 2622185 Status: Offline Sonork: 100.1675196 Thanks Meter: 19 | no bixby key i have j410f bineries mixed up no download no bixby . what to do? |
The Following 2 Users Say Thank You to Amin0092 For This Useful Post: |
