Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 04-02-2014, 15:20   #1 (permalink)
Member: 2123431
GT-i9505 stuck on logo with recovery booting
i have there one samsung i9505 nd i flash near about 10 time in odin flashing is all done but after restart its stuck on samsung logo and in corner recovery booting if somebody have solution just post here thanx
Old 04-03-2014, 13:55   #2 (permalink)
Member: 2123431
i think no body have solution
Old 04-04-2014, 17:58   #3 (permalink)
Member: 238772
Thanks Meter: 8
I also have 2 pcs same problem. I tried everything in software n repaired boot with riff box but every thing success but same issue. I am going to try hardware n reply
Old 04-05-2014, 18:37   #4 (permalink)
Member: 238772
Thanks Meter: 8
I made 2 units in hardware 10000% success. Don't wast time is software
Old 04-05-2014, 23:45   #5 (permalink)
senses's Avatar
Member: 548988
Sonork: 100.1624541
Thanks Meter: 10
What is the solution for it?
Hardware what?
Old 04-06-2014, 06:29   #6 (permalink)
Member: 1720209
Thanks Meter: 2
small tips:
check volume + button... try to desolder it.
if your phone will power up normally you must replace the switch.
Old 04-07-2014, 05:23   #7 (permalink)
Member: 238772
Thanks Meter: 8
Heat this red marked aria then phone will start normaly after that flash the phone with 4.4.2. using odin. after software done imei will be blank then rebuild imei number. now job is done
The Following User Says Thank You to niflas For This Useful Post:
Old 04-07-2014, 12:14   #8 (permalink)
Member: 2123431
i have extra mother board demo unit and i take same ic from demo unit and put it on stuck recovery mode mobiler now the phone is dead
Old 04-09-2014, 04:56   #9 (permalink)
Member: 238772
Thanks Meter: 8
I made 2 phones both are working perfectly
Old 04-09-2014, 05:16   #10 (permalink)
mrrobin's Avatar
Member: 888712
Thanks Meter: 308
flash with 4.4.2 firmware,last time i face this problem after done
Old 05-04-2014, 13:51   #11 (permalink)
Member: 45873
Thanks Meter: 35
19505 vibrates and restarts every sec
flased different files of ver 4.4.2
even tried 4 files firmware with pit .
Able to enter recovery and download mode
details in download mode
Product code:GT-I9505
current binary:Samsung official
system status:Custom
Knox Kernel Lock:0x0
Knox warranty Void:0x1
CSB-CONFIG-LSB:0x30
Write Protection: Enable
eMMC burst mode:enabled
any suggestions
Regards
Riaz
Old 05-04-2014, 17:25   #12 (permalink)
Member: 45873
Thanks Meter: 35
Problem solved
It was power switch problem
Regards
Riaz
Old 05-04-2014, 20:22   #13 (permalink)
Hussain_Mobile's Avatar
Member: 681758
Sonork: 100.1676160
Thanks Meter: 347
1 check battery
2 power swtich
3 try to flash on 4.4
in last check on hardware
Enjoy
Old 05-21-2014, 16:19   #14 (permalink)
Member: 514031
Thanks Meter: 7
i have sam probleme i n my i9505
in download mode
CSB-CONFIG-LSB:0x30
pls how solvet it
The Following User Says Thank You to sidah_gsm For This Useful Post:
Old 08-06-2014, 16:03   #15 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
Originally Posted by ddjadav View Post
Thankyou very much
it works like charm
How is the procedure?
First heat, then reassemble phone, then insert battery and turn on the phone?
br
The Following User Says Thank You to huzein For This Useful Post:
Page generated in 0.19524 seconds with 8 queries
