Samsung read/write eeprom with flash cable HOW?? hi all, Does anyone knows how to read / write eeprom into samsung phones using flash cable. I know its possible but i dont know how. Thanx a million for your help. |
tool box 4.3 |
How to use Tool box 4.3.1 to read and wite full eeprom? In E2P manager only have R/W field piece by piece ! Which value for offset mode read? Please get the link to download Toolboxhelp. Best regards! |
Where is the link to download toolbox help. anyone or any other software???????? |
@essojay I also need it, did You find anything? |
with samsung test program terminal via test mode. This program is included in the Imei changer . But only for few models. And U should write a program that uses this protocol :) |
Hi essojay ! if you need toolbox 4.3.1 , please contact me by ICQ:163939663 Best regards. |
I HAVE TOOLBOX4.3.1 AND EEPROM FILES DO NOT KNOW HOW TO REMOVE SYSTEM FAILURE CONTACT PROVIDER HELP! |
Solution - thanx to nokiaunlocker - Open toolbox Go to 'e2p manager', press 'program on' select 'eeprom' then 'e2ptstpattern' at the top select 'write to eeprom' type in the box : 0x2767 tick 'send command to phone' and then press 'reset' om the left side TWICE the phone should reboot and that should be it! Not mine solution, again....... But tested on 2 pcs, 100% working!!!!!!! |
Toolbox v4 and manual download link: |
Hi Can someone tell-us how to upload full good eeprom to SAMSUNG R210s, which software to use? and which cable (is it the same to flash?)? Thanks;) |
read old posts mourad |
Why doesn't anyone explain what and step by step should we do to write that ****ing eeprom in the phone.Does or doesn't anyone know for sure? |
@mobileland Everybody knows, but no1 wants to say...... Mail me |
Thanks shoneb, I'll call you! |
