Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
07-19-2018, 10:33 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 44
Member: 179813 Status: Offline Thanks Meter: 13 | Samsung S8 G950F RPMB PROVISIONED [FLASHING PROBLEM] I'm having a problem with a S8 G950F. It turns out that I was trying to remove the FRP from it and I flashed the equipment about 5 times between combination file and original file. When I mixed sboot and booted with one another to have ADB (something I usually do on other devices and I can remove the FRP) it always kept restarting with the message NAD: FAILED DAS: AP, BLOCK: FUNC, LEVEL: 5, VECTOR: G30_unzip NAD SECOND: FAILED DAS: AP, BLOCK: FUNC, LEVEL: 5, VECTOR: G30_unzip RPMB PROVISIONED I have had times that this message appeared but now as soon as I try to put the original ROM or any ROM the equipment restarts as soon as one tries to write anything. Odin error: <ID:0/087> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/087> Odin engine v(ID:3.1301).. <ID:0/087> File analysis.. <ID:0/087> Total Binary size: 5471 M <ID:0/087> SetupConnection.. <ID:0/087> Initialzation.. <ID:0/087> FAIL! (DeviceInfo) <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/087> Removed!! This error happens with chimera, z3x, odin, putting the 4 files and the PIT. Has it ever happened to anyone? |
07-19-2018, 10:50 | #2 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,274 | Phone enters download mode or remains on this stage as shown IF THIS POST WAS HELPFULL PRESS BUTTON |
The Following User Says Thank You to souma_k For This Useful Post: |
09-28-2018, 17:26 | #7 (permalink) |
Insane Poster Join Date: Aug 2010 Location: *****a spain
Member: 1372401 Status: Offline Thanks Meter: 13 | please try latest update and before flash disconnect battery 10 sec i hope it will be done I have updated box with latest software How can u disconnect battery on s8 g950f ??? XXU2 binary will work for 8.0 XXU3 ????? thankyou |
09-28-2018, 17:34 | #8 (permalink) |
Member: 1372401 Status: Offline Thanks Meter: 13 | sorted out With the octopus I downloaded this software G950FXXU2CRF7_G950FOVF2CRF3_OMN.zip I flashed and he did not restart from scratch and started writing Hello bronks i hav g950f with RPMB Provisioned device has XXU3CRGH fw 8.0 after installing "s.boot" combi firmware XXU3ARG1 phone is stuck with logo & RPMB provisioned. cannot install anything,fail msg nor full combi fw,nor original 8.0 formware connection error setup connection..... initialzation...... phone reboots any reccomendation ???? thankyou |
10-04-2018, 18:24 | #9 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: South Coast UK
Member: 58075 Status: Offline Thanks Meter: 17 | Quote:
10-05-2018, 17:53 | #10 (permalink) |
Member: 1372401 Status: Offline Thanks Meter: 13 | Flash just this then you can flash normal firmware and phone will be ok Attached Thumbnails Click image for larger version Name: rpmb.jpg Views: 11 Size: 19.8 KB ID: 368585 Hello bronks Thanx a lot for ur instructions,it worked finally with combination fw. Got stuck in nad msg in screen,installed original firmware & looks goin good. Big thankyou. I was trying to remove frp on this s8 binary 3,with combination fw downloaded from a link uploaded on this forum. if you have any suggestion regarding remove frp S8 G950f XXU3CRGH pls it would be grt help & appreciated. will not try with earliar combination,in case device gets stuck again somewhere. thanx again. |
10-08-2018, 19:59 | #12 (permalink) |
Member: 1372401 Status: Offline Thanks Meter: 13 | samsung g950f 8.0 Binary 3 frp reset done sucessfully. As "amleto90"says it works. installed full combination binary 3 uploaded by "souma k". activate usb debugging & reset frp via combination with octopus. install original fw without "recover.img,cache.img,userdata"& done. device gets on without frp. to desactivate OEM,just go onto developer options & disable OEM. Now u have frp & Oem off. After working & checking lots of information,i got success. Big thankyou to all |
