Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
07-08-2003, 14:10 | #1 (permalink) |
No Life Poster Join Date: Jul 2000 Location: hiroshima Age: 51
Member: 1756 Status: Offline Thanks Meter: 9 | any solution for Probleme parametrage retour SAV ? with arm processor i think that could be possible, but i guess with infineon processor, there is no solution at all, i've read all post in all forums any advice is welcome thx |
07-08-2003, 18:16 | #2 (permalink) |
No Life Poster Join Date: Mar 2002
Member: 10175 Status: Offline Thanks Meter: 0 | And what kind of processor is used in that phone? If its Firmware 4,X its Infineon, if its 3,X its ARM. For Infineon, you can at least read the whole eeprom. Entering Monitormode should be possible for both. You need to edit field 0 at first to get another error message. Then the THS9 code will work. Do not forget to note the original value for field 0 :-) |
07-09-2003, 03:15 | #3 (permalink) |
Member: 1756 Status: Offline Thanks Meter: 9 | thanx chriss for your answer phone is IMEI: 350800351211577 Firmware: 307251519468 Type: DI4,6I: 1519 Date: 25-07-02 edited field 0, and always have same error message and THS9 code doesn't work, tried all possibilities |
07-09-2003, 08:11 | #4 (permalink) |
Member: 10175 Status: Offline Thanks Meter: 0 | You can read the full eeprom anc compaire it with a eeprom from another Phone with the same firmware. Best is: Get two eeprom backups from other Phones with the same firmware and see, what fields are the same in those two backups. Then compaire these fields with the data in your phone. Perhapes you will fins something what is wrong |
Is there any solution for problem in SPD "SOS Calls only" | ezzis | SpiderMan | 1 | 08-19-2008 10:48 |
Any Solution for LG 81xx Unlocking problem? | pakstar | LG | 6 | 04-17-2006 00:25 |
any solution for c350 charging problem | MichieMax | Motorola P2k | 1 | 10-02-2004 18:13 |
Any solution for R250 speaker problem after IMEI change | andri | Old Ericsson Phones & Sony Phones | 8 | 05-10-2002 23:12 |
Any Solution for 8250 " Hang" Problem? | xpmobile | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 01-25-2002 02:56 |
