mw930 s2-d2 with mw30xx soft? Can this be done? I have allready tried mw3026 software to get phone ID from MW930 and calculate simlock code. But phone wont accept it, now I am thinking to enter field 251 to the phone by pony prog. Have anybody tried this and what is the result? <br />regards<br />Me@n |
Yes.Put new hex value to fiel 251 with poniprg. and phone work.I tested.<br />Zuti |
Zuti - thanks for your reply. regards<br />Me@n Hvala na odgovoru majstore! |
You can write hex values direcly to field 251 with<br />sagem doctor no read modify and write eeprom<br />regards |
Are you sure ?<br /> Eeprom field 251 in MW930 is protected and you need pony to read it. regards<br />Me@n |
yes 930 D2 FF3,1T is protected. Sagem Dr. no write this field. sorry my English. |
Hi to all! I have mw930 s2 d2.<br />phone ID : 080A81C12141<br />field 0 : 083A23813235633723<br />feld 191 : 3B37397D calculated unlock code : 09827697<br />new field 251 : 0x3A93E06D<br />this code MUST be ok - some people calculate code from logs of this phone & code the same... Phone says that code is incorrect. I check field 251 with ponyprog - 0x3A93E06D in eeprom. One man try unlock this phone befor, may be he change some data...((( what can i do in this situation? Thanx! WBR, MegaSlava |
Hi again:-) I unlock this MW930! I calculate new code & field 251 with new value of field 251/191 - 0x3A93E06D and recieve new value for 251 - 0x3B37397D (it was my field 191). After this i change field<br /> 251 to 0x3B37397D by ponyprog and phone with code 09827697 is unlocked! I don't know why in this phone field 191 was 0x3B37397D and 251 was 0x3A93E06D! I hate sagem phones! <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> Thanx for help soft by Karlo and Cbot! WBR, MegaSlava |
Hi MegaSlava To what addresses in dump eeprom S2-D2 FF3,1T there are fields 191 and 251? WBR,Guest |
2 Guest. Use sfe003 to find addresses of this fields. WBR, MegaSlava |
Hi! <img src="smile.gif" border="0"> Where can i get sfe003 and how do i read as well as change the fields? How do i know which values to put in those fields? |
2 MegaSlava: 10x. Your solution good works. <br />2 datalife2000: check mail. |
[quote]Originally posted by Me@n:<br /><strong>Are you sure ?<br /> Eeprom field 251 in MW930 is protected and you need pony to read it. regards<br />Me@n</strong><hr></blockquote> Ok guys excuse my ignorance just today i've a 922<br />ft4.1m from D2.impossible to read field 251 with sagem doctor after many tries the phone shows<br />"serv unruf"message i'm not skilled in deutsh but<br />i see the meaning is return to "CS" how can restore the phone at least to accept D2 card<br />regatds |
