Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
10-07-2002, 22:48 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: x
Member: 4989 Status: Offline Thanks Meter: 13 | Hardware failure on a 939 FW4,0V Field 231 is protected and also in hotline menu there is no PROM option. |
10-08-2002, 10:13 | #2 (permalink) |
No Life Poster Join Date: Nov 2001 Location: türkiye Age: 59
Member: 7114 Status: Offline Thanks Meter: 51 | this versiyon hash 20 there are only 2 solution one off them for mine. 1.take out eeprom 231 00 this known metod....... 2.give 5 volts to pin 1 to your soket and read my old topic I don't know excatly where I told all off this solution before |
10-08-2002, 10:49 | #3 (permalink) |
Member: 4989 Status: Offline Thanks Meter: 13 | I've clearly specified that there is no eeprom inside, if it would, the phone would've been to the customer by now !!!! As for second method you better be more explicit. Thanks P.S. Maybe downgrade will help, but I don't know what file to use, phone being D2-S7 with no eeprom. Last edited by mr_x4you; 10-08-2002 at 11:08. |
10-09-2002, 10:43 | #6 (permalink) |
No Life Poster Join Date: Mar 2002
Member: 10175 Status: Offline Thanks Meter: 0 | Mr X4You: You can try the fix231 (Bootstrap)Tool from Hannes, perhapes this works for your firmware, too. Or you can change field 268 from 0C 00 to 0C 01 and restore the checksums for this field. Then you can start the phone again, even if the counter is at 05 or more ... Then you can enter the correct unlock-code (if your field 5374 is untouched) and i hope, this resets the counter to 0, too and unlockes the phone... Good luck. |
10-09-2002, 14:39 | #8 (permalink) |
Member: 7114 Status: Offline Thanks Meter: 51 | @chris this versiyon checksum area not visibble sagem doctor doesn't work. regards I don't know hannes bootstrap I look last post I didn't find give me please that program link. thanks Last edited by ardagul; 10-09-2002 at 14:52. |
10-09-2002, 16:11 | #9 (permalink) |
Member: 10175 Status: Offline Thanks Meter: 0 | http://www.michaelgrieser.com/gsm/un...gem/fix231.zip Here it is.. But now, i see.. It is not suitable for mr_x4yous phone. Its made for MW930 FF3.1T (1905) (I successfully tested it with this version), but perhapes it works for other MW 9xx phones, too. |
939 FW4,1M Hardware Failure | MPS | Infineon C16X M51 & ARM7 M52 BASED | 5 | 10-30-2002 10:36 |
SAGEM MC930 FW4.0V please help | anry | Infineon C16X M51 & ARM7 M52 BASED | 1 | 09-04-2002 21:15 |
ANYBODY CAN REPAIR SIMLOCK on my SAGEM MC930 FW4,0V S7 ??????????????? | anry | Infineon C16X M51 & ARM7 M52 BASED | 3 | 12-07-2001 00:24 |
Unlock SAGEM MW930 FW4.0V | antonello | Infineon C16X M51 & ARM7 M52 BASED | 0 | 11-05-2001 10:09 |
939 hardware failure ,mobile blocked ,what to do? | igor_m | ARM9 BASED M62 / M62+ | 1 | 09-27-2000 08:54 |
