ARM9 BASED M62 / M62+ All MYxxx Like: MY C3-2, MY X1-2, MY Z-55, MY X2-2, MY C-4, MY Z-3, MY C2-2,
MY V-75, MY X3-2, MY X-7, MY V-65, MY C-1, MY X-1w, MY C-6, MY C-5w, MY C-2, MY
X-2, MY X-6, MY G5, MY X-3, MY X-5, MW X1, MY V-56, VS2, VS1, MY C5-2, MY X-8,
MY X-4, MY C4-2, MY V-55, MY X5-2, MY C-3b, MY C-3s,MY100, MY200, MY300X, MY400, MY V-85, MY V-76,
MY X6-2 etc Also SG321i, VS3 & MY-S7 (Smart Phone) |
06-09-2004, 18:59 | #1 (permalink) |
Junior Member Join Date: Apr 2004 Age: 61
Member: 63106 Status: Offline Thanks Meter: 0 | how to use sagem code reader step by step i connected wires red, blue, yellow, and black to sagem test points by soldering.connected dongle to LPT port, connected data cable to dongle and phone. run sagem code reader v10.switch phone on, select version of phone(i.e myx-1). but when i select LPT 1 i get a message that "error in the main module ; contact seller for upgrade". please i'm i doing something wrong? maybe the connections are wrong?thanks in advance. |
06-10-2004, 09:48 | #4 (permalink) |
No Life Poster Join Date: May 2004 Location: SCOTLAND Age: 39
Member: 65016 Status: Offline Thanks Meter: 0 | yes connect the lead ti the usb port and put the other end into the dongle sorry about not replying ealier i have been busy helping a freind unlock a new myx-7 |
06-10-2004, 10:03 | #6 (permalink) |
Member: 65016 Status: Offline Thanks Meter: 0 | yes sorry i forgot to tell you that the phone must be on for to read codes but if you still have the same problems e-mail me again and i will help you john |
06-10-2004, 21:19 | #7 (permalink) |
No Life Poster Join Date: Nov 2003 Age: 39
Member: 44610 Status: Offline Thanks Meter: 50 | Man just download a upd file and exe file (v13)from ur support area may be (www.gsminfo.pl) then connect dongle but dont forget to put the upd and exe file in the same directory and run. after updating dongle all will be ok then reconnect testpoints then read codes. BR Didi |
06-11-2004, 09:17 | #8 (permalink) |
Insane Poster Join Date: Oct 2003 Location: East Africa,Tanzania,Mwanza Age: 55
Member: 40578 Status: Offline Thanks Meter: 0 | Hi, I need help i have sagem Myx2 and Myx5m I cant unlock with dongle sometimes it says error bad connection and some time says check data cable phone not found please help and the picture says different colour test point and I have different colour wire please help my wire colours are red,green, black and yellow and pic I attach show different |
06-11-2004, 09:35 | #9 (permalink) |
Member: 65016 Status: Offline Thanks Meter: 0 | because u r using origional the colours are different yellow wire = blue red wire = green black wire = brown green wire = orange i hope this helps john |
06-11-2004, 11:00 | #11 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Brazil
Member: 52490 Status: Offline Thanks Meter: 8 | Check the soldering points that they are not making contact to any adjacent ones. Check that the data cable is connected correctly. Restart the SCDR and try again after that. Hope this helps. NH |
06-11-2004, 14:16 | #12 (permalink) |
Member: 44610 Status: Offline Thanks Meter: 50 | 33% bad connection?? This happens when u interchange one color for the other... so check well. And dont soldertest points again inorder to avoid destroying points. Use pins on the test points and try again . Br Didi |
06-12-2004, 13:01 | #13 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Call my cell, I will dash you a test point adapter Quote:
I guess U are in Nigeria by your name. Call my mobile line, I have a set of test point jigs for all phones supported by clone CDR. This is what is being sold to most Nigerians as Original by a smart guy. I can give them to you. With this, you never have to bother about cable colour, soldering, pin touching, working with 2 ppl etc. You just unlock the phone under 1 minute Till then | |
How to use Sagem Code Reader | tical | ARM9 BASED M62 / M62+ | 5 | 10-04-2004 23:16 |
how to write sagem code reader hex with galep III programmer | surfer2go | ARM9 BASED M62 / M62+ | 1 | 04-24-2004 15:02 |
How to use Sagem Code Generator | tical | Infineon C16X M51 & ARM7 M52 BASED | 9 | 04-22-2004 12:58 |
search pinout for data cable for myC2 using sagem code reader v11 | patric | ARM9 BASED M62 / M62+ | 1 | 02-16-2004 13:17 |
how to use sagem dongle 2.3 | riaad | ARM9 BASED M62 / M62+ | 2 | 09-22-2003 23:07 |
