ARM9 BASED M62 / M62+ All MYxxx Like: MY C3-2, MY X1-2, MY Z-55, MY X2-2, MY C-4, MY Z-3, MY C2-2,
MY V-75, MY X3-2, MY X-7, MY V-65, MY C-1, MY X-1w, MY C-6, MY C-5w, MY C-2, MY
X-2, MY X-6, MY G5, MY X-3, MY X-5, MW X1, MY V-56, VS2, VS1, MY C5-2, MY X-8,
MY X-4, MY C4-2, MY V-55, MY X5-2, MY C-3b, MY C-3s,MY100, MY200, MY300X, MY400, MY V-85, MY V-76,
MY X6-2 etc Also SG321i, VS3 & MY-S7 (Smart Phone) |
05-24-2004, 09:38 | #1 (permalink) |
Freak Poster Join Date: Sep 2003 Age: 55
Member: 39023 Status: Offline Thanks Meter: 0 | My C2 Test Point And Clone Dongl???? Can Some One Give The Right Pin Out Of The Clone Dongle To Build It In Detail Please Frindly |
05-29-2004, 19:30 | #4 (permalink) |
No Life Poster Join Date: Nov 2003 Age: 39
Member: 44610 Status: Offline Thanks Meter: 50 | Check Here... http://forum.gsmhosting.com/vbb/show...light=MyC2+Pin next time make use of the search button. Br Didi |
05-31-2004, 14:16 | #6 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Brazil
Member: 52490 Status: Offline Thanks Meter: 8 | easiest way is really to buy the C2 cable from the dongle supplier, or any of the other suppliers. I bought the dongle, and immediately also the C2 cable. Easy as hell to unlock... cable is around 12$USD, worth the investment. NH |
06-07-2004, 00:47 | #9 (permalink) | |
No Life Poster Join Date: Apr 2002 Location: Germany Age: 54
Member: 11273 Status: Offline Thanks Meter: 14 | Quote:
Hi New_Here Can u explain more how it "Easy as hell to unlock...", how did you connect battery and hold 4 pins to test points in the same time. why I get always "Bad Connection" Immediatly after pressing "Read Code", with other Sagems dongle works OK. br | |
06-07-2004, 09:18 | #10 (permalink) |
Member: 44610 Status: Offline Thanks Meter: 50 | Man, Just solder testpoints and put the battery on top of it (the battery is not so big that it cannot allow it to close). connect dongle and cable to it and click read code, for me it work 100% perfectly on 10 phones. Br Didi |
06-07-2004, 10:05 | #11 (permalink) |
Member: 11273 Status: Offline Thanks Meter: 14 | thanks BadUnlockers for yr reply, I did exactly what u wrote, I get always "Bad Connection" Immediatly after pressing "Read Code" with 100% blue progress bar, I have updated my dongle (Originaly v12.1) to v14 with file downloaded from gsminfo.pl, but the same problem, have u any idea? br |
06-07-2004, 10:13 | #12 (permalink) |
Member: 44610 Status: Offline Thanks Meter: 50 | then check ur test point well..... U can contact me then i send u a good testpoint pic for C2. I'm online @ yahoo ([email protected]) br Didi |
06-07-2004, 10:30 | #13 (permalink) |
No Life Poster Join Date: Apr 2001 Location: AGADIR Morocco
Member: 3936 Status: Offline Thanks Meter: 237 | it will be easier to get correct testpoints for C2.if you compare for exemple X5 pinsout for clone and original dongle you can put table for colors yellow from original is blue for clone black is brown orange is green and blue is orange you should know now how to solder test points on c2 regards |
06-07-2004, 11:53 | #14 (permalink) |
Member: 11273 Status: Offline Thanks Meter: 14 | my test points are ok: DB 9.2: Red DB 9.3: Orange DB 9.8: Blue DB 9.9: Violet I tested this pins connection is ok, without connnection with test points I see messege "Waiting for connection" with moving points in CDR, but when test points are connected with pins the progress bar quickly ride to 100% and "Bad Connection" come within 0.5 second |
Sagem MY C4 test point !!! | KATOUE | SagMaster Team OLD Products | 58 | 04-11-2006 20:31 |
Sagem My-C2 test point description | gsminfo | ARM9 BASED M62 / M62+ | 2 | 04-22-2005 13:22 |
My-C2 test point need for Sagem CDR v12 | marianhritcu | ARM9 BASED M62 / M62+ | 9 | 05-21-2004 19:10 |
My X3 test point | bzpsmachine | ARM9 BASED M62 / M62+ | 2 | 02-04-2004 22:58 |
