ARM9 BASED M62 / M62+ All MYxxx Like: MY C3-2, MY X1-2, MY Z-55, MY X2-2, MY C-4, MY Z-3, MY C2-2,
MY V-75, MY X3-2, MY X-7, MY V-65, MY C-1, MY X-1w, MY C-6, MY C-5w, MY C-2, MY
X-2, MY X-6, MY G5, MY X-3, MY X-5, MW X1, MY V-56, VS2, VS1, MY C5-2, MY X-8,
MY X-4, MY C4-2, MY V-55, MY X5-2, MY C-3b, MY C-3s,MY100, MY200, MY300X, MY400, MY V-85, MY V-76,
MY X6-2 etc Also SG321i, VS3 & MY-S7 (Smart Phone) |
04-07-2004, 21:03 | #1 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 49032 Status: Offline Thanks Meter: 0 | MyV-65 hardware failiur i have a sagem V-65 fone displays this message ''hard ware faliur phone blocked'' i have tried to read field 268 with charger connected but it does not works on v-65,i have checked my cable with myx5m and it is working. is there some other method to read fields in camera fones?? |
04-07-2004, 21:41 | #3 (permalink) | |
Member: 49032 Status: Offline Thanks Meter: 0 | Quote:
hi i have just succeded to read and edit field ,it was 0c 00 and i make it 00 00. ok then reset by wokshop 1.35 ,now again it is making problems to rewrite original value 0c 00 .it is not conncting again ,,,,now phone displays SIM LOCKED without sim, plz guide me what to do now. | |
04-09-2004, 21:57 | #6 (permalink) |
Member: 49032 Status: Offline Thanks Meter: 0 | i have tested it erliar [when it shows hardware failuir] with scr v-13 reset counters,but it allways showes error. now if i use scr dongle at lpt and test points but rs232 cable at com attached to phone,,,could sagum doctor works to read that field ?? is there any posibility to reads phone using both [scr &its test points only] and com cable using sagem doc ?? |
04-10-2004, 07:50 | #7 (permalink) |
No Life Poster Join Date: Nov 2001 Location: türkiye Age: 59
Member: 7114 Status: Offline Thanks Meter: 51 | no change with lastest versiyon myv-65 ...also +5v pin 1 solution doesn't work..sometimes (change with versiyon)... good luck...reading fields easy but not all... |
myV-65 hardware fault dead | kage | Sagem Hardware Repair Area | 2 | 06-24-2006 12:45 |
Help me need flash files myV-55 and myV-65 | ssatcom | Redbox | 0 | 11-20-2005 13:23 |
myv-65 hardware failure permanently blocked!!! | kcgckc2002 | ARM9 BASED M62 / M62+ | 10 | 08-25-2004 19:21 |
MYV-65 & MYV-75 | keat | Phone Unlocking Codes & Maps | 0 | 06-20-2004 12:01 |
Myv-65 Unlock | viho | ARM9 BASED M62 / M62+ | 9 | 12-08-2003 18:06 |
