ARM9 BASED M62 / M62+ All MYxxx Like: MY C3-2, MY X1-2, MY Z-55, MY X2-2, MY C-4, MY Z-3, MY C2-2,
MY V-75, MY X3-2, MY X-7, MY V-65, MY C-1, MY X-1w, MY C-6, MY C-5w, MY C-2, MY
X-2, MY X-6, MY G5, MY X-3, MY X-5, MW X1, MY V-56, VS2, VS1, MY C5-2, MY X-8,
MY X-4, MY C4-2, MY V-55, MY X5-2, MY C-3b, MY C-3s,MY100, MY200, MY300X, MY400, MY V-85, MY V-76,
MY X6-2 etc Also SG321i, VS3 & MY-S7 (Smart Phone) |
04-18-2004, 03:56 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: tunisia kairouan Age: 47
Member: 3768 Status: Offline Thanks Meter: 77 | repair build sagem dongle simple solution tested 100% this is schematic tested |
04-18-2004, 13:33 | #4 (permalink) |
Member: 3768 Status: Offline Thanks Meter: 77 | all bignner no see haw repair or build the dongle with schematic i help him is very simple to build it morte question contact me here +216 98 238 031 |
04-18-2004, 17:11 | #5 (permalink) |
Major Poster Join Date: Apr 2000 Location: Strasbourg, France Age: 59
Member: 1296 Status: Offline Thanks Meter: 0 | easy programmer interface with few wire to solder to make yourself for very low cost. no need to remove any mcu, or opening dongle http://resolv.info.free.fr/images/bo...ight_shema.JPG elari Last edited by elari; 04-18-2004 at 20:35. |
04-18-2004, 22:25 | #6 (permalink) | |
Registered User Join Date: Dec 2002 Location: The Netherlands Age: 41
Member: 19168 Status: Offline Thanks Meter: 55 | Quote:
please give more explanation on how to repair and which program to use. I have the dongle and it has usb port option too. please tell me how to? thanx in advance just some links for program and some useful informations is appreciated | |
04-19-2004, 12:15 | #8 (permalink) | |
Freak Poster Join Date: Nov 2002
Member: 17702 Status: Offline Thanks Meter: 0 | Quote:
Also: All the resistors are 75R or some of them must be 100R? Which ones? B.R. | |
04-21-2004, 02:39 | #9 (permalink) | |
Freak Poster Join Date: Feb 2004 Location: Planet Earth Age: 67
Member: 54300 Status: Offline Thanks Meter: 20 | I have made a scheme of the famous easy programmer interface (txt joined) but could anybody verify the scheme coz on the link it's not very clear. If somebody know answer he could correct the txt and send it back. Thanks in advance Quote:
04-21-2004, 08:18 | #10 (permalink) |
Member: 1296 Status: Offline Thanks Meter: 0 | hello computs it means you have to short (sold a wire)pin 2 to12 & pin 3 to 11 on db25 male (en fr : tu relie la broche 2sur12 et 3sur11 de la db25 male) all other are from the male to the female db25. hope it'll help you br ps : as this easy prog does not use any buffer, it is better to connect directly to the mainboard lpt port without any cable extender. and you need to apply the power from the usb cable (in fr : il est conseille d'utiliser l'interface directement sans cable et d'alimenter le dongle avec le cable usb) |
04-21-2004, 20:15 | #11 (permalink) | |
Member: 54300 Status: Offline Thanks Meter: 20 | Thanks elari for your support, i have understand. two phases need to be clarified too. pin 18 and 25 shorted on male and female but m&f soldered together. 11 male go to 3 female already 12 male go to 2 female already Scheme joined in txt is ok now confirm? ( en fr: tu relies les broches 18 et 25 aussi bien dans la prise male et femelle mais tu relies male et femelle quand même par 18m---18f ou 25m--25f, la broche 11m est reliée à 3f et 12m à 2f en plus du shortage 2m--12m et 3m--11m? Mon schéma joint est juste normalement) Thanks for all elari hope will have news of you soon. Computs Quote:
(NEW) Simple Solution Repair X35 Phone Dead (Tested 100% Work) VERSION 2 | rinvend | x1x to x45/x50 | 21 | 07-28-2020 08:41 |
.: Who want to repair his Sagem dongle in PAKISTAN :. | Jani-Jan | Sagem Hardware Repair Area | 11 | 01-28-2006 16:01 |
Repair Your Sagem Dongle Yourself Help ??? | muller | ARM9 BASED M62 / M62+ | 0 | 05-14-2004 14:55 |
(NEW) Simple Solution Repair X35 Phone Dead (Tested 100% Work) VERSION 2 | rinvend | x1x to x45/x50 | 11 | 07-18-2002 15:38 |
Simple Solution Repair X35 Phone Dead (Rate if Work) | rinvend | x1x to x45/x50 | 7 | 05-18-2002 09:40 |
