ARM9 BASED M62 / M62+ All MYxxx Like: MY C3-2, MY X1-2, MY Z-55, MY X2-2, MY C-4, MY Z-3, MY C2-2,
MY V-75, MY X3-2, MY X-7, MY V-65, MY C-1, MY X-1w, MY C-6, MY C-5w, MY C-2, MY
X-2, MY X-6, MY G5, MY X-3, MY X-5, MW X1, MY V-56, VS2, VS1, MY C5-2, MY X-8,
MY X-4, MY C4-2, MY V-55, MY X5-2, MY C-3b, MY C-3s,MY100, MY200, MY300X, MY400, MY V-85, MY V-76,
MY X6-2 etc Also SG321i, VS3 & MY-S7 (Smart Phone) |
10-31-2004, 16:37 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Mauritius Age: 47
Member: 7482 Status: Offline Thanks Meter: 24 | sagem cdr v14 cannot connect to any phone i have sagem code reader it was working perfectly yesterday and today when i try to connect it to unlock a sagem My-X2 i get error message "Phone not found! Check data cable!" I have been trying to check each testpoint, i have even try to solder every soldering point in dongle and i have read a lot of things about reprogramming sagem dongles since morning. i have tried to reprogram it with ESUPD and sagemreader10.1.flash.hex I have even tried to repair it with srepair14 i have successfull flashed the ATMEL16 with srepair14 and updated with the 5860550C.upd file created. But still i get error message as written above "Phone not found! Check data cable!" I have tried to change settings of BIOS for parallel port. I tried every options given, But still can't find phone. I have been using the sagem code reader for more than 6 months without any problem. the problem is not with the phone, i have try it with 2 more phones but still can't find phone. I have tried 1 My-X5 and 1 My-X5m Please can anyone help me I am using win98 motherboard is ASUS processor is Geniun Intel 1.8 Ghz Please help me to repair my sagem code reader dongle friends? WBR Mehvishal |
11-01-2004, 07:19 | #3 (permalink) | |
Freak Poster Join Date: Feb 2004 Location: __________ Age: 44
Member: 52668 Status: Offline Thanks Meter: 1 | Quote:
you should check how cable is connected to cdr! the try to change only data cable!! post result,if not, other solution will be explained | |
11-01-2004, 17:28 | #5 (permalink) |
Member: 7482 Status: Offline Thanks Meter: 24 | hi friiend have checked all connections of datacable all seems to be ok with datacable Please suggest me another method to repair or to find the fault in my dongle friends WBR Mehvishal |
11-13-2004, 12:14 | #6 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Germany Age: 54
Member: 11273 Status: Offline Thanks Meter: 14 | @ Mehvishal Hi m8 have u repaired ur dongle??? I have the same problame exactly as u explained, I have even bought new data cable with "test point" adapters and tried with many Sagems but no way, I get always "Phone not found! Check data cable!". what happened with my CDR?? I didn't touch it 2 monthes and now it will not function http://forum.gsmhosting.com/vbb/showthread.php?t=168714. is there any solution?? br |
11-13-2004, 12:21 | #7 (permalink) | |
for example www.asmax1.narod.ru/files/sagem/original_scr.zip this one! post result | |
11-15-2004, 10:12 | #10 (permalink) | |
Member: 11273 Status: Offline Thanks Meter: 14 | Quote:
I haven't this models right now. what a difference from other sagems?? I have tried with my 3026, myx 65, mc 930 but can't detect any of them! what should I do? br | |
11-15-2004, 10:55 | #11 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Try to use this soft cdr 14 in windows Xp .Or check testpoint. All the phones Sagem which i have to unlock i use win Xp and if the soft say Phone not connected Check data cable for me testpoint wrong |
11-15-2004, 13:02 | #13 (permalink) | |
thank u Unlocker AL for answer, I have test point adapters and cable with test point Needles, both connected good to test points but I think this is a dongle problem. br | |
11-17-2004, 11:29 | #14 (permalink) | |
11-17-2004, 11:32 | #15 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Portugal- Center of Europe Age: 42
Member: 9502 Status: Offline Thanks Meter: 9 | if the sw open withou error that is because sw is ok! can you send me pictures of you dongle inside and i will help you solve this! my email is [email protected] your problem is on your datacable! maybe you re not making test point correct! send me the pictures of the dongle opened and cable and i will help! chers |
spider man box not connecting to any phone | bilalzaink | Chinese Models & Cloned Phones | 3 | 06-09-2009 13:11 |
infinity not connect to any phones | sulaiti | Infinity-Box | 2 | 12-15-2008 19:51 |
micro box not connecting to any phone | phonestand | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 10 | 10-10-2008 14:24 |
Help!My box cant connect to any phone using 13.20 installer??? | DAVI | Cruiser Suite | 1 | 08-21-2008 08:48 |
Can not connect to any phone in PBB? | The Repair Shop | Phoenix Black Box | 3 | 03-09-2006 20:02 |
