Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
12-15-2001, 19:59 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Uranus Age: 53
Member: 5072 Status: Offline Thanks Meter: 91 | C35 Switches off after pressing the menu button rgds<br />themobileking <img src="cool.gif" border="0"> |
12-17-2001, 06:03 | #4 (permalink) |
Freak Poster Join Date: Dec 2001 Location: JavaLand
Member: 7743 Status: Offline Thanks Meter: 0 | Yes...it could be bad battery.<br />It's usually happen.<br />Try use your battery on other C/M/S 35 phone to make sure battery condition. -------------------------------<br />I need C/M/S 35 Flash v23 & v25 pls...<br />[email protected] |
12-24-2001, 03:30 | #6 (permalink) |
No Life Poster Join Date: Jul 2001 Location: md Age: 25
Member: 5379 Status: Offline Thanks Meter: 0 | open ur phone, seems u got a bad contact at the back pcb, where there must be a contact for volume and voice recording button in S35i, that button contact also exist in C35i, even it's not used, a bad contact at that area will cause phone switch off when u push menu + any button |
12-25-2001, 17:16 | #8 (permalink) |
Junior Member Join Date: Dec 2001 Location: Netherlands
Member: 7892 Status: Offline Thanks Meter: 1 | Hi too you all. If you want to resolder anything.. ..and i think that's where it's al about if you reheat a component. USE FLUX AND ALWAYS USE FLUX. The tin in the mobile is a non flux type. that contents no flux from his self. So is you want to let it flow again en make it like new. Use flux. Check your local hardware store for the right one. I always use flux from:<br />Alpha metals inc. Lot no:00010881<br />It's WriteFlux Cleanline nr205.<br />It does'nt need cleaning because you can put it exactly on the right spot because it's in a waterproofmarker style packing. Have good luck. (an no i don't have stocks in alpa metals inc. <img src="smile.gif" border="0"> ) I use a Pace Hot AIRJET. On a Pace microbenchtop unit. (GOOD STUFF) |
Voda 125 switched off on pressing call button | chhoton | Various | 1 | 02-28-2010 09:28 |
7310c hang up and shut off after pressing the key pad!!! | danielccape_ask | Nokia Base Band 5 ( BB-5 ) | 4 | 02-25-2010 13:45 |
3100 switch off when press goto | MAMAMOBILE | Nokia Digital Core Technology 4 ( DCT-4 ) | 28 | 03-03-2009 08:52 |
L6i SWITCH OFF WHEN PRESS ANY BUTTON | jamohaki | Motorola Hardware Repair | 0 | 04-12-2008 08:02 |
V200 freezing and switching off after some key presses... | Burnt Cobba | Samsung Hardware Repair | 0 | 10-13-2005 08:40 |
