Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
07-25-2001, 11:28 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | S25 keypad malfunction Green button ( which used to execute call ) cannot work, also 4,5,6,* ,0 ,#. When i try to replace my first board to another S25, Its OK. Where is the path connected to ?? PLS Hlp rgds Note : Mobile King, where r u ??? |
07-25-2001, 21:47 | #2 (permalink) |
Freak Poster Join Date: Jul 2001
Member: 5364 Status: Offline Thanks Meter: 0 | Hi BBand, No idea where cct leads 2 but if u compare on working board u will find that there is copper track common to 4,5,6 and another track common to *,0,# Both these tracks seem 2 be damaged.Trace where they lead 2 on ok pcb & u should find yr fault.I will check on ok board 4 u 2morrow. |
07-26-2001, 15:18 | #5 (permalink) | |
Freak Poster Join Date: Apr 2001 Location: INDIA
Member: 4223 Status: Offline Thanks Meter: 4 | Quote:
Hi BBAND... How r u?... Ok there is Simple fault of Strip between two Board (MAin board and Display Board)... Just MAke clean the Connector and REfix it.. Yr problem must b solved.... Good Luck | |
07-29-2001, 11:35 | #7 (permalink) |
No Life Poster Join Date: Jul 2001 Location: md Age: 25
Member: 5379 Status: Offline Thanks Meter: 0 | hi BBand, i think that's the time u have to replace your cable flexible, after a long time use, the cable will have one or two fractured line, if not, the contact place where we insert the cable have made a big hole in the soldering place |
t230 keypad malfunction | katicutie | Sony Ericsson | 7 | 06-09-2006 13:04 |
T230 keypads malfunction | ber747 | Sony Ericsson Hardware Repair | 6 | 08-21-2005 09:30 |
x105 keypad malfunction solution | MARKIE41 | Samsung Hardware Repair | 2 | 06-07-2005 12:01 |
p910i keypad malfunction | ber747 | Sony Ericsson | 0 | 05-28-2005 11:58 |
509 keypad malfunction... read on :) | trafix | Various | 9 | 03-02-2002 09:24 |
