Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
11-12-2002, 22:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: Slovakia, Brezno
Member: 2721 Status: Offline Thanks Meter: 23 | SL 45 powering off problem But when vibrating allert and backlight is powered off, all is OK. Phone can make a call so i thing PA is OK. I tryed new wel working battery, but problem remains...any help? Please? |
11-14-2002, 01:48 | #4 (permalink) |
Freak Poster Join Date: Apr 2002 Age: 50
Member: 10736 Status: Offline Thanks Meter: 0 | i have the same problem but the phone writes low battery recharge even with a new batt from a working phone some times i change the PA and it will work but sometimes i need 2 but something like melted cilicon inside the cover to press the board and it works but 3 of 10 works with me when i change the PA . Even i tried software but nothing ? Iam going to be crazy from this . |
06-02-2003, 01:30 | #5 (permalink) |
Junior Member Join Date: May 2003
Member: 30159 Status: Offline Thanks Meter: 0 | genocite... what you describe is the problem I am having. Could you possibly help me out with that? (this was the only post I found that mentioned it) Longer desc of problem: When no SIM in, phone stays on in or out of charger, even after backlight goes off. With SIM in, phone stays on after backlight turns off if connected to charger. If phone is not connected to charger and backlight goes off and SIM is in the phone turns off. If you keep using the phone so the backlight doesn't go off, it is fine (until backlight goes off) edit: my phone is an SL45 with FW56. |
sl 45 turn off | pava | Siemens Hardware Repair Area | 0 | 12-25-2004 01:24 |
To all members making 5510 power on -insert sim-power off problem working 100% | KISHOMETO | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-16-2003 03:18 |
3310 power off problem | joe locks | Nokia Hardware & Hardware Repair | 1 | 09-10-2002 21:49 |
T20 power off problem | duda | Sony Ericsson Hardware Repair | 5 | 02-17-2002 05:22 |
Sl 45 Phone Code problem | xxxpaga | x1x to x45/x50 | 0 | 01-09-2002 21:02 |
