05-14-2005, 20:53 | #1 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Uzhgorod, Ukraine Age: 47
Member: 3023 Status: Offline Thanks Meter: 1 | 6630 flashed successfully but don't power on. Today I tried to flash a 6630. I did these steps. Using latest firmware 6630 RM-1_dp_v_6.0_MCUSW4.050318_EURO.exe with updates 6.01, 6.02 and 6.03 (this firmware has only a few LPs) 1. Tried with Flash package 3.26 and this didn't worked. 2. With Flash package 3.19 and with default settings of Giffin it was successfull both the MCU and the PPM, but after flashing the phone won't power on. Removed that firmware, downloaded and installed RM-1_dp_v_5.0_MCUSW3.0445113_EURO.exe (which is the previous version with all european LPs) 1. Tried with Flash package 3.19 again with Griffin defaults and again successfull flashing with a dead phone at the end. 2. Downloaded and tried Flash package 3.21 and the results are the same. What's the problem and how can I repair this phone? Is it safe to try to full erase this phone with trial2.fia full erase file posted somewhere on this forum? WBR, Chris. |
05-16-2005, 14:37 | #8 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: GSM world Age: 49
Member: 111249 Status: Offline Thanks Meter: 531 | Quote:
BR | |
05-17-2005, 11:24 | #9 (permalink) |
Member: 3023 Status: Offline Thanks Meter: 1 | I used the 5 pin cable, but the phone still flashable, it can be flashed successfully, but won't power on. I'll try to find the 7-pin cable scheme, and mobify my cable. |
05-17-2005, 14:17 | #10 (permalink) |
No Life Poster Join Date: Dec 2003 Location: INSIDE FIBER OPTICS
Member: 47271 Status: Offline Thanks Meter: 25 | 5pins Cable Almost The Same With 7pins The diffrent of two cables in the 9v Supply I Think You Can Use 7pins or 5pins cable in griffin Just Remove the 9v supply in vpp Br c2r2 |
05-18-2005, 11:27 | #11 (permalink) |
Member: 3023 Status: Offline Thanks Meter: 1 | I modified my 5 pin cable to 7 pin, but the results are still the same - phone flashed successfully, but won't power on. Anyone has a solution for this? |
05-18-2005, 14:32 | #13 (permalink) |
Member: 3023 Status: Offline Thanks Meter: 1 | I modified my 5 pin cable to 7 pin, but the results are still the same - phone flashed successfully, but won't power on. Then I flashed the full erase file trial2.fia and then the MCU and PPM. Now the phone goes to local and test modes, but can't start up normally: the "nokia" message at boot fades out and the phone restarts. Any solution for this? |
05-19-2005, 11:57 | #15 (permalink) |
Member: 3023 Status: Offline Thanks Meter: 1 | I played with that phone a bit and found out the following: 1. Tried to full erase and flash with MCU and PPM of ver. 3.0445113 and the phone powers on to an endless loop with NOKIA fading out of the screen. 2. Tried to do the same but with ver. 4.050318 and the phone won't power on at all. So, there is something strange with that 4.050... One more question is about PPMs starting with V1RM1 V2RM1 and V3RM1. Are they some special PPMs for special phones? According to the product code and appropriate ini, in the befinning my phone had PPM V1RM1_3.0445113.v57 but it won't work with this same MCU and PPM now. |
M620 Flashed successfully but don't Power on. | ummhere | HWK | 3 | 09-01-2009 12:57 |
3250 flash ok but don't power on | gsmspace | Nokia Hardware & Hardware Repair | 4 | 07-15-2007 09:38 |
V550 flash OK but don't power on???? | midou01 | Smart-Clip | 6 | 09-12-2005 07:01 |
