12-03-2004, 21:22 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Age: 40
Member: 30801 Status: Offline Thanks Meter: 6 | 6630 Flashing Problem Can i flash my 6630 with griffin platinum box.I have cable and flash file.I use lastest griffin soft.I select RM-1 and product code. But when i click on FLASH.The soft give error that says INVALID MCU FILE IS SELECETED.Also when i try to flash only ppm.The error is the same thay PPM FILE IS INVALID. Is there any one in word who is able to flash 6630 with GRIFFIN Best Regards |
12-27-2004, 07:12 | #8 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: La Paz Age: 53
Member: 17431 Status: Offline Thanks Meter: 22 | Quote:
BR, LogoMan | |
12-28-2004, 02:24 | #10 (permalink) | |
BR, LogoMan | |
12-30-2004, 15:42 | #14 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | @ irishclips no mate it doesnt, but then if you'd read the above posts you would've seen that for y'self so far the only 2 things that can successfully flash/unlock 6630 is either Nokia Phoenix, or PBB. It needs to be flashed through the pop port using a dku 2 cable im sure though that saras team will eventually find a way round this problem, or at least i hope they do... regards jay |
6630 flash problem!!!! | classgsm | Phoenix Black Box | 9 | 10-05-2005 22:59 |
6630 flashing problem.. | ryumahon | Griffin | 1 | 07-04-2005 08:28 |
