06-22-2005, 20:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Fairyland
Member: 3383 Status: Offline Thanks Meter: 3 | 7610 flashing problems with griffin 2.0895 ????? i have this 7610 which came to me for language changing , but when i tried to load the ppm it erased the ppm then stoped saying flashing failed error, then i tried to flash the complete mcu n ppm but still i get the same problems here is what griffin says : V3.4 BoxID:FF8A SN: ******** ACTIVATED BOX Trying autopower using autopower Initializing Phone... Flash configuration: 9F0400EC00F82200001100100002EC00... Boot and Flash loaders operation took 11.938001 seconds Erasing - erase took 0.420000 seconds Flashing MCU 00000000:0000012C, 04Flashing FAILED Make sure phone is connected and powered! ErrCodes: [13:FFFFA300] any suggestions on how to revive this phone , pls all help me ,,,,,,, the client is very upset with me |
06-22-2005, 22:37 | #2 (permalink) |
Freak Poster Join Date: Jul 2001 Location: :-)
Member: 5376 Status: Offline Thanks Meter: 1 | Hi Delete: -Program Files\Nokia\Phoenix\Flash -Program Files\Nokia\Phoenix\Flash3 -Program Files\Nokia\Phoenix\FlashUsb Install FlashDirs_fia_351 and all will be ok Regards |
06-22-2005, 22:57 | #3 (permalink) | |
No Life Poster Join Date: Nov 2002
Member: 17424 Status: Offline Thanks Meter: 15 | Quote:
Hi I have same problem. where can we get FlashDirs_fia_351 ?. thanks for you help br msa | |
06-24-2005, 16:45 | #4 (permalink) |
Member: 3383 Status: Offline Thanks Meter: 3 | THNX FM-GSM OK a step ahead now , the flashing of mcu starts after i changed the fia_dir_351, with older version of flash file se;lected it shows like this V3.4 BoxID:FF8A SN: ******** ACTIVATED BOX using autopower Initializing Phone... Flash configuration: 9F0400EC00F82200001100100002EC00... Boot and Flash loaders operation took 11.634001 seconds Erasing - erase took 0.401000 seconds Flashing MCU 00000000:0000012C, 00Flashing FAILED Make sure phone is connected and powered! ErrCodes: [13:0000] with newer version then the phone it behaves like this : V3.4 BoxID:FF8A SN: ********* ACTIVATED BOX using autopower Initializing Phone... Flash configuration: 9F0400EC00F82200001100100002EC00... Boot and Flash loaders operation took 11.167001 seconds Erasing - erase took 0.391000 seconds Flashing MCU 00000000:0000012C, 04Flashing FAILED Make sure phone is connected and powered! ErrCodes: [13:FFFFA300] & with the version in the phone that is 404374 it behaves like this : V3.4 BoxID:FF8A SN: ******** ACTIVATED BOX using autopower Initializing Phone... Flash configuration: 9B0400EC00F8220000110002EC00F822... Boot and Flash loaders operation took 9.552000 seconds Erasing - erase took 327.313016 seconds Flashing MCU 0021C000:00002000, 00Flashing FAILED Make sure phone is connected and powered! ErrCodes: [13:0021] but almost 70% cursur runs (blue blocks of flashing status) n then it says ERROR MCU FLASHING FAILED ?????? ANY MORE SUGGESTIONS ,,,,,, PLS HELP Last edited by PTR999; 06-24-2005 at 17:10. |
06-24-2005, 17:20 | #5 (permalink) | |
No Life Poster Join Date: May 2004 Location: Bandung-Flasher.com
Member: 65947 Status: Offline Thanks Meter: 135 | Quote:
install 2.0881 work for me.... BR | |
Problem flashing 7710 using Griffin 2.0895 | jachu51 | Griffin | 3 | 02-03-2006 22:56 |
...6630 Flashing Problem with Griffin... | LoveLess | Griffin | 15 | 12-31-2005 09:42 |
Cant flash 6630 with griffin 2.0895 | FX1 | Griffin | 6 | 10-26-2005 10:46 |
Problems flashing 6620 with Griffin 2.0895 | UnlockBR | Griffin | 4 | 05-15-2005 17:35 |
