10-21-2003, 07:08 | #1 (permalink) |
Junior Member Join Date: Oct 2002 Age: 42
Member: 16481 Status: Offline Thanks Meter: 0 | Failed to Get Imei & Msid In 3310 When i try to upgrade my 3310 to ver. 6.07 after flashing it show the error ' Failed to get IMEI & MSID ' now phone is totaly dead it tryed flasher with windls & dejn 1.0b but no result please help me if any idea to retry my phone Soujith |
10-21-2003, 14:02 | #2 (permalink) |
No Life Poster Join Date: Aug 2003 Location: BiH
Member: 37090 Status: Offline Thanks Meter: 42 | @Soujith, Reason for this is poor cable connection. I had same problems with some 3310, 3410, etc (some of them totaly dead, some with messed menus). Make sure that cable and phone connectors both are clean, and have good connection, then do reflash phone again (and again, if necessary). |
10-22-2003, 08:50 | #3 (permalink) |
Member: 16481 Status: Offline Thanks Meter: 0 | Sir, Yes i thing problem is with cable because i have total 32 pcs with same problem in that 32 i retry 16 pcs with reflash and cleaning the connector i am trying to retry remaning pcs thanks for the replay Soujith |
05-19-2004, 10:59 | #4 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | i have a 3310 with a wrong msid , its 000000000 and i was not able to read it with rolis..., it stops in the middle. theni full flashed it to lower and higher version both but now it is dead , i can only flash it but it does not starts at all, what could be the problem? y did this set does not starts after flashing? thanks please reply... |
Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
Nokia E71 Unlock Failed - BB5 Unlock Failed -> Failed to get Lock Key (6, 5) | ronzinio | Cyclonebox | 6 | 01-15-2010 14:34 |
Griffin 3310..failed to get IMEI | tical | Griffin | 0 | 10-05-2006 23:32 |
2100 Failed to get Phone MSID | supremegsm | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 10-13-2003 04:24 |
