09-16-2004, 14:03 | #1 (permalink) |
Junior Member Join Date: Oct 2003 Location: Romania Age: 49
Member: 42719 Status: Offline Thanks Meter: 0 | griffin 2.86 ...dct3 flashing error regards DrHigh |
09-16-2004, 14:15 | #2 (permalink) |
Freak Poster Join Date: Oct 2001 Location: bootcore Age: 49
Member: 7069 Status: Offline Thanks Meter: 6 | My work fine Yesterday I flashed 4 DCT3 headset with Griffin 2.86-8210,8850,3310 and 5100 in all phone procedure was sucsessfull.Check your interface cable(LPT) |
09-16-2004, 14:27 | #3 (permalink) |
Member: 42719 Status: Offline Thanks Meter: 0 | about dct3 5110 what fia do u use ..... if i do the dct3 detect ... the phone is detected ....but when i try to fla**** ...the phone automaticaly powered on and i got the same message 003d....... error...... |
09-16-2004, 14:50 | #4 (permalink) | |
Member: 7069 Status: Offline Thanks Meter: 6 | Quote:
NO MORE LOCK`S! | |
09-16-2004, 15:47 | #5 (permalink) |
Member: 42719 Status: Offline Thanks Meter: 0 | maybe the cable .... may be cable for 5110 ...do u have a working schematic ..for 5110 ...the 3310 problem was solved ....i changed the fia and works ...but the 5110 still not.... maybe u have a cable pinout for 5110 6110 6210 .... and the corect resistor |
09-16-2004, 16:35 | #6 (permalink) |
Member: 7069 Status: Offline Thanks Meter: 6 | Test your cable with a 6210/6310 if work than you`ll need correct fia/boot loaders.Try with this:switch ot your 5110 with griffin service cable,should be powered,than press reset box button,if your phone is switch off ,your cabe is Ok. NO MORE LOCK`S! |
twister DCT3 flashing error | .::AkhavanGSM::. | Twisterflasher | 3 | 05-31-2013 19:35 |
Griffin DCT3 Flashing error???? | laughatlife85 | Griffin | 1 | 03-26-2006 14:09 |
griffin 2,86 mmc card format | sevgigsm | Griffin | 3 | 11-21-2004 18:15 |
griffin 2.86 error writin 5110,6210 ????? | drhigh | Griffin | 5 | 09-24-2004 17:35 |
DCT3 FLASHING ERROR PROBLEM, read pls | dannyogolo | Nokia Multimedia | 3 | 09-30-2003 06:01 |
