09-19-2004, 18:01 | #1 (permalink) |
Freak Poster Join Date: May 2003 Location: Caribbean Age: 70
Member: 28074 Status: Offline Thanks Meter: 12 | I need HELP!! How to flash with Griffin Box I can't find any tutorial to do this in the tutorial area of this forum and I will apreciate any HELP!!! |
09-20-2004, 21:38 | #2 (permalink) |
Freak Poster Join Date: May 2004 Location: Teneife Age: 56
Member: 64313 Status: Offline Thanks Meter: 1 | There is no tutorial for this. I had the same problem when i first got my griffin box, its just trial & error. if the griffin box detects the phone then just select the firmware (MCU) you want to load to the phone and then it should ask you to chose a langauge pack (PPM), select the one you want and press "flash" after its finished press unlock when done disconect, put in the sim card and see if its all working ok. I killed the first 3 phones i done because i didnt have a clue what all the files i downloaded was for, i got the message "contact service" but after a couple of day i got them back to to life. You cant do any real damage, so give it a try, if you muck it up try again. good luck Steve |
09-20-2004, 22:06 | #3 (permalink) |
Freak Poster Join Date: Jun 2003 Location: www.ats-com.com >> Jakarta, Age: 97
Member: 32069 Status: Offline Thanks Meter: 4 | Yes right. And don't forget to check : - Manual Mode - Set Full Factory After Flash Sometimes those setting can repair your phone better. BR, Adam www.ats-com.com |
03-16-2005, 18:38 | #5 (permalink) | |
Member: 32069 Status: Offline Thanks Meter: 4 | Hi... YES. It is compatible with 1100, 2600. BR, Adam Quote:
RH-93 need help how to flash it with mt box using patch file | amirgsmbejaia | MT-BOX | 1 | 03-25-2009 23:16 |
Needs Help,How to Flash a dead M600i with SeToolBox? | gdclub | Sony Ericsson | 0 | 03-28-2008 12:27 |
how to flash with mt box | gsmbun | MT-BOX | 4 | 01-28-2006 08:45 |
how to flash with twister box | boostin | Twisterflasher | 2 | 01-01-2005 19:05 |
Need help! How to flash G450 with Russian | NSerN | Panasonic | 0 | 02-27-2002 16:00 |
