09-28-2003, 22:45 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | A solution that fixed 3650 freezing on Nokia Logo for Griffin users. use this file Nhl83022.0c4 in PPM area ONLY. flash the phone in manual mode. check manual mode and factory setttings after flash. after flashing has been done After flash processing will fail... jsut power on phone and griffin must continue to do the job and at the end it MUST do factory reset ... set OK soemthing like this :- Initializing Phone... Erasing Flashing PPM Flashing DONE After flash processing... Phone data: V E37/27-12-02/NHL-8/(c) NMP. IMEI XXXXXXXXXXXXXXX Set Factory Default Settings set OK No Java upload specified AfpOK after that the phone will start normally and should not hang up. Chinese langauge should crop up . Now jsut flash european flash and that is all. the phone should be ok. PS. pity this cant fix all 4X fading. This problem is not always fixable not even the ppm erase. br to all and hope it will help those with this problem if they did not succeed with the ones said by others al |
10-08-2003, 23:01 | #4 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | guys forgot to add something.... this also applies to the cousin of 3650.... 7650 the big problem however is the 50% chance for 4X fading that it can be fixed or not on 3650. br to all al |
nokia 3250 its freezing on nokia logo | shakil143 | Nokia Hardware & Hardware Repair | 2 | 06-27-2011 16:10 |
nokia 3650 bling on nokia logo | ..::Mr999::.. | WD2 & APE (Symbian Phones) | 9 | 10-08-2010 11:57 |
nokia 3650 hang on nokia logo | ijogo | Nokia Hardware & Hardware Repair | 1 | 06-30-2007 12:00 |
3650 hangs on Nokia logo | FractalizeR | Griffin | 7 | 09-06-2003 12:05 |
