Federal One Federal One & Prodigy Support Section |
11-24-2006, 10:40 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: La Paz Age: 53
Member: 17431 Status: Offline Thanks Meter: 22 | Federal One Box can't write rpl to 1112 NSS: DCT4PLUS Simlock Rebuild started. NSS: Reading phone info...Done. NSS: ->SW: V 5.53 20-07-06 RH-93 (c) NMP NSS: ->IMEI: 353647014526090 NSS: Updating Firmware... always stop on updating firmware... Its my first log to open it Br, Logoman |
11-24-2006, 11:15 | #3 (permalink) | |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Quote:
Try to flash the phone, if flashing works, then the log upload will work as well. You can enable debugging in the flashing dll, according to the Debuggin.txt document and attach log here also. Regards | |
11-24-2006, 18:49 | #4 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Manila, Philippines
Member: 10541 Status: Offline Thanks Meter: 8 | i also can't write requested rpl to my 1112. here's the log: NSS: Reading phone info...Done. NSS: ->SW: V 5.53 20-07-06 RH-93 (c) NMP NSS: ->IMEI: 35325301037xxxx NSS: Updating Firmware...Done. NSS: Checking phone...Done. NSS: Phone Resp: RH-93 NSS: Rebuilding locks...File Error! NSS: Updating Firmware...Done. NSS: Checking phone...Done. NSS: DCT4PLUS Simlock Rebuild End ->Not Successful i lost 2-credits. i requested twice thinking that my first attempt was wrong. so i requested again but i got the same error. i saved the rpl inside NSS root directory, but i got error then put it inside backup/rpl but same error. what should i do then? thanks, mvr |
11-24-2006, 20:06 | #5 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Romania Age: 45
Member: 95698 Status: Offline Thanks Meter: 5 | The Rpl file should be in NSS/Backup/RPL This is why is not working PLease put the rpl file in the directory from above and it will work Regards Chance_gsm |
11-25-2006, 05:33 | #10 (permalink) |
Member: 10541 Status: Offline Thanks Meter: 8 | @ logoman, try to contact speed. i also have a problem last night about my 1112 v5.53 unlocking, but we sorted out that problem in less than 10mins. you may need to uninstall the latest version of nss and install the one speed has given me (nss v. 1.0.38.4). this one works for me but with a little trick in writing rpl. hope you will solve your problem. wbr, mvr |
11-29-2006, 17:43 | #11 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 92178 Status: Offline Thanks Meter: 14 | Got problem also writing rpl file.. Generated ask, got reply from server, put the rpl in the backup\rpl folder select write in the logging box and get the following error.. NSS: DCT4PLUS Simlock Rebuild started. NSS: Reading phone info...Done. NSS: ->SW: V 3.21 20-07-06 RM-189 (c) NMP NSS: ->IMEI: 359746009305140 NSS: Not supported model/version! Thanks for any help/info |
11-29-2006, 18:39 | #12 (permalink) | |
No Life Poster Join Date: Nov 2001 Location: China GuangDong
Member: 7220 Status: Offline Thanks Meter: 1,592 | Quote:
Best Regards Alan Tan | |
same n70,one box can sx4,one box can't sx4 | ken6430841 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 12-13-2009 20:43 |
federal one box | stevefillby | Genie Universal | 1 | 07-13-2009 00:25 |
Can't write RPL to 7373 cabel is ok this is software problem pleasse fix this !! !! | wgmmmx | Federal One | 18 | 04-20-2007 10:58 |
federal one box where to buy? | infinitydabest | Federal One | 6 | 03-14-2007 11:28 |
