03-26-2004, 01:17 | #1 (permalink) |
Crazy Poster Join Date: Nov 2003 Location: Sheffield, UK Age: 42
Member: 44457 Status: Offline Thanks Meter: 1 | MS Q323183 Bluetooth Patch for XP-SP1 'vs' MS XP-SP2 BT I've noticed a few differences. The XP SP2 Driver actually works! Well, it does with my phone! The Q323183 driver only offers a "DUN" service - which isn't veyr useful to me. The SP2 driver includes a "Nokia PC Suite" service and a "COM Port" service. Using the "Nokia PC Suite" service I've succesfully synchronised my 6310i with outlook, and modified some of its contents with Nokia Phone Editor. I haven't yet tested any other software but I'm pretty optimistic about it. The SP2 version also adds a nice system tray icon, and replaces the former control panel applet with a new applet with a few more options. If this does work for others as it seems to for me then it will save a LOT of hassle with the widcomm drivers for a lot of people. I suspect however that the new MS Drivers won't include all the services that many people want. Infact I can only see the COM Port service and PC Suite service (which is a com port based service), so people wanting other features may struggle. There does seem to be some mention of a PAN (Personal Area Network) but I haven't had chance to test this yet. If anyone has any other info about SP2 Bluetooth Support then please let the rest of us know! Cheers |
03-26-2004, 23:52 | #2 (permalink) |
Junior Member Join Date: Feb 2004 Age: 41
Member: 54476 Status: Offline Thanks Meter: 0 | I've been working on the SP2 BT drivers for a few weeks now. They definatly do seam a lot better than the existing patch for MS users. However there do still seam to be problems.... 1) Using Serial ports, only 1 port ever gets added no matter how many devices you try and make it work through [even tho it suggests otherwise]. All my devices go to COM21 which means it causes some software not to work properly [can't make 2 apps listen on 1 com port]. 2) Serial port is unreliable. You quite often loose access to the port. I have found that many pieces of software have problems where they can no-longer connect to the port until you restart [althougth this may be a non-SP2 problem]. 3) PAN network support is pretty much useless. I tried making it work, but it turns out it cannot be used to make a BT PAN network, but rather only connect to it [VERY annoying - Ģ50 for a bluetooth hub]. However, it does make the bluetooth dongle work quite nicly with P800, P900, Palm m505 [with bluetooth adapter]. File transfer works, as does serial port accesses remotely [although as I said above only just]. leemperor, you said you had a new tray icon for it. I never got that... what does it look like, and what does it do? |
03-28-2004, 12:14 | #3 (permalink) |
Member: 44457 Status: Offline Thanks Meter: 1 | looks quite similar to the widcomm system tray icon. a little bluetooth icon. It gives you access to the control panel options and various other bits. see screenshot |
03-29-2004, 02:43 | #4 (permalink) |
Member: 54476 Status: Offline Thanks Meter: 0 | Ta for reply leemperor.... huh, I didn't get that. I might give removing all the MS crud and putting it in again another try. Did you already have the MS stuff installed when you installed SP2 leemperor? |
03-29-2004, 15:20 | #5 (permalink) |
Member: 44457 Status: Offline Thanks Meter: 1 | I did a fresh install from an XP CD with SP1 slipstreamed into it. Then I installed SP2. Didn't have any other patched installed before I installed SP2 call me Jon if you like, its shorter |
03-31-2004, 02:11 | #6 (permalink) |
Junior Member Join Date: Mar 2004
Member: 60538 Status: Offline Thanks Meter: 0 | I've just installed windows XP SP2, but you said that "The SP2 driver includes a "Nokia PC Suite" servic", I could not found where the service was. Please tell me how to use "Nokia PC suite" service . Thank you! |
04-01-2004, 04:13 | #7 (permalink) | |
Member: 54476 Status: Offline Thanks Meter: 0 | Quote:
Need updated patch for Toshiba BT Stack 5.10.12 | ulysse | Bluetooth-Software | 0 | 11-22-2007 16:32 |
15pcs Windows XP Professional OEM English w/SP2 | crusher | Exchange Section | 1 | 09-12-2006 22:40 |
<<Connecting Problems with XP SP1..?Read HERE>> | randy_d4 | Motorola P2K (USB-Smart) | 9 | 07-06-2006 16:07 |
win xp patch for scr 12.1 | ChelasGsm | ARM9 BASED M62 / M62+ | 4 | 08-12-2004 03:57 |
