05-03-2006, 14:08 | #1 (permalink) |
Junior Member Join Date: May 2006
Member: 270491 Status: Offline Thanks Meter: 0 | Plz help cant get widcomm to work |
05-03-2006, 14:20 | #2 (permalink) |
Junior Member Join Date: Jan 2005 Age: 44
Member: 104980 Status: Offline Thanks Meter: 0 | There is a newer version out but 802 seems to be the most stable up untill now. I had the same problem, like alot of other people. Go into the Device manager: Right click My Computer > Manage > Device managment Now in here find your bluetooth dongle and do the following: Right click on device > Update Driver > No not this time > Advanced > Do not search I will choose the driver to install Now select the driver which is not signed, the one without the green check mark behind it (it will probably be at the bottom). Now it shoudl work. |
05-03-2006, 14:30 | #3 (permalink) |
Member: 270491 Status: Offline Thanks Meter: 0 | Now select the driver which is not signed, the one without the green check mark behind it (it will probably be at the bottom). ... i cant find aything there... the are many icons 2 for bluetooth it says show all devices and alot more... must i click show all devices??? and there??? must i go to microsoft???because my dongle is from microsoft??? i have no idea thx fo help |
05-03-2006, 14:50 | #5 (permalink) |
Member: 270491 Status: Offline Thanks Meter: 0 | http://img410.imageshack.us/img410/8108/17up4.jpg http://img325.imageshack.us/img325/7441/20rq.jpg http://img325.imageshack.us/img325/8643/38ei.jpg am i correct doing it like this??? plz help |
05-03-2006, 16:26 | #7 (permalink) |
Member: 104980 Status: Offline Thanks Meter: 0 | Hmmz what it actually shoud do (and what it does with me) is give you a list of all compatible devices instead of goto a list of all devices. Maybe somebody else can help here? |
05-03-2006, 16:50 | #9 (permalink) |
Member: 270491 Status: Offline Thanks Meter: 0 | maybe its because i still use the service pack bluetooth driver... because i tried many times now... if i uninstall the sp2 bluetooth driver i dont have one anymore... u know where to get a bt driver for a bluetooth dongle from microsoft??? |
05-03-2006, 19:58 | #11 (permalink) |
Freak Poster Join Date: Oct 2003
Member: 40901 Status: Offline Thanks Meter: 2 | Ive got two different microsoft bluetooth dongles and both work fine with widcomm. You may well have to add your device to the inf file for it to work though, and there are plenty of topics on here discussing how to find out your pid/vid and update the necessary inf file. |
05-03-2006, 20:17 | #12 (permalink) |
Member: 270491 Status: Offline Thanks Meter: 0 | Are u the 1 who wrote this 01-14-2004, 18:58 The byte sequences that seem to work for all of the most recent revisions to the widcomm drivers are: search for 83C40885F60f85ef000000 and replace 0f85ef000000 in the sequence with 909090909090 search for 8BF083C40C3BF5750E3BFD750A and replace 750e with 9090 and 750a with 9090 you need to do this on the following 3 files: BTTray.exe (typically in c:\program files\widcomm) BTStackServer.exe (lives in the same directory as BTTray.exe) WBTAPI.DLL (lives in c:\windows\system32 or c:\winnt\system32) I tried it with the version i mentiened above but the hex data is only in 1 of the files... can u explain me how to do what u are saying??? i know its probably alot to ask... but i have no idea and i sitting for ofer 15 hours now infront of the pc and i cant get it to work... i need to get bluesoleil or widcomm to work for my logitech freedom headset to work... |
05-03-2006, 20:58 | #14 (permalink) |
Member: 40901 Status: Offline Thanks Meter: 2 | Dont bother trying to crack the files yourself, just use one of the automatic patchers mentioned in the posts relating to the newer versions of widcomm. Its the btwusb.inf you need to edit with the correct vid & pid. |
Cant get cruiser to work, HELP!!! | ford72 | Cruiser Suite | 8 | 04-03-2008 23:11 |
cant get ustpro to work on xp | jab | UST Pro II | 3 | 04-12-2007 20:16 |
i have dongle from gsm unlock cant get software to work ??? | yzf | ARM9 BASED M62 / M62+ | 6 | 08-06-2003 12:33 |
I CANT GET DEJAN TO WORK! | dario | Nokia Hardware & Hardware Repair | 1 | 01-27-2001 11:01 |
