03-31-2007, 05:02 | #1 (permalink) |
Major Poster Join Date: Jan 2006 Location: somewhere on the Mediterranean
Member: 223748 Status: Offline Thanks Meter: 3 | Toshiba Bluetooth Stack 5.10.06 available Changes of Bluetooth Stack 5.10.01(T) -> 5.10.06(T): - Installation process of Windows XP was updated - "to Bluetooth" menu was not shown if logged on as "Restricted user" mode. It is fixed now. - Sound mute issue was fixed - "COM Auto Connection utitity" multiple COM connection issue was fixed. - Sound driver updated to improve sound quality with A2DP connections. - Printer registration issue was fixed. - DUN setup window focus isse was fixed. - Scanner device registration process was updated. - Hi-Speed USB hub issue on Vista systems was fixed. - HSP/HFP registarion process was updated. - Passkey character table was expanded. |
04-05-2007, 02:46 | #3 (permalink) |
Member: 223748 Status: Offline Thanks Meter: 3 | Yes, it works with CSR (there have never been issues there with Toshiba). You will probably have to use the patcher in order to get around the 30 day trial. |
05-07-2007, 21:51 | #10 (permalink) |
Junior Member Join Date: May 2007
Member: 502985 Status: Offline Thanks Meter: 0 | I have a liscense for Toshiba Bluetooth Stack v4.xx. Do I have to use a crack for this, or is there a legit upgrade path? The only reason i need to use this is because for some reason, the 4.xx stack will not install properly on a clean winxp install. |
12-09-2007, 21:33 | #14 (permalink) |
Junior Member Join Date: Sep 2007
Member: 590977 Status: Offline Thanks Meter: 0 | Vista When using windows vista, move the .exe file outside the program files folder (special permissons problem), for example: d:\ If you then patch the file, it will succeed, then move it back to the program files folder and overwrite the original .exe. Works like a flow! |
Toshiba Bluetooth Stack Version 7.10.04 is now available | SLB | Bluetooth-Software | 19 | 11-04-2010 22:34 |
New Toshiba BT Stack 5.10.15 and 5.10.16 | ulysse | Bluetooth-Software | 6 | 04-16-2008 14:38 |
Need updated patch for Toshiba BT Stack 5.10.12 | ulysse | Bluetooth-Software | 0 | 11-22-2007 16:32 |
Problem using skype with Toshiba BT Stack 5.10.06 and Motorola headset HT820 | max888 | Bluetooth-Software | 0 | 04-18-2007 19:40 |
Toshiba BT Stack 5.10.01 for 2k/XP/Vista available | ulysse | Bluetooth-Software | 18 | 02-10-2007 19:11 |
