02-01-2005, 22:22 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 54
Member: 112141 Status: Offline Thanks Meter: 0 | Trying to initiate Headset Connection with Headset using the Bluesoleil Software I was able to initiate the connection between the dongle and my Logitech Bluetooth Freedom Headset with the button on the headset. Due to some problems with that software I changed to Widcomm 4.0.1.700. But now I can only start the connection from within "My Bluetooth Place" followed by a ringtone in the headset and pressing its button. Whe I try to connect to the PC without using Quick Connect there before, nothing happens. Any suggestions ? |
05-28-2005, 14:33 | #2 (permalink) |
Junior Member Join Date: May 2005 Age: 47
Member: 148760 Status: Offline Thanks Meter: 0 | Hey, there I got a worse situation as you had. my headset works fine with blueboleil as well. but with widcomm, no matter I initiate from "my bt place" or the button of headset, nothing happens! Have you solved your problem or not? |
Trying to flash Nokia 8600 with Phoenix 2008.04.007.32837 and failing. Please Help. | brawas | Nokia Base Band 5 ( BB-5 ) | 1 | 06-27-2008 15:20 |
Failed to establish USB connection with z310i | soudies | Cruiser Suite | 7 | 08-12-2007 08:45 |
Trying To Unlock A V3 With Bad Usb Port | bengrippin | Motorola P2k | 1 | 06-10-2006 20:14 |
w900i trying to change the language with a cruiser V9.03 | jonathanjosorio | Sony Ericsson | 1 | 02-11-2006 15:49 |
w900i trying to change the language with a cruiser V9.03 | jonathanjosorio | Motorola P2k | 2 | 02-10-2006 00:23 |
