Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 02-27-2006, 16:27   #91 (permalink)
Member: 237850
Thanks so much for helping me in making it possible to use the widcomm drivers.
I used the 5.0.1.1200 drivers with the Widcomm_pather_v2.zip posted here. But the installation didn't go as smooth as expected. When i patched, restarted and plugged the dongle in, windows always intalled the microsoft drivers for it and the widcomm control panel couldn't see the dongle. So i removed the microsoft drivers before plugging it in to make it work.
Thanks again
Old 02-28-2006, 00:12   #92 (permalink)
Member: 238108
one q plz
does nokia pc suite work with widcommmm
quick ans plz
Old 02-28-2006, 09:22   #93 (permalink)
Member: 237675
Question
Originally Posted by mifronte
...installing and patching the Widcomm 5.0.1.1200 bluetooth software and driver. I was able to install it on my DELL Latitude D810 with Dell Wireless 350 Bluetooth internal module.
The Widcomm stack works flawlessly like it should be in a plug and play environment.
Hi All,
I have the same Dell environment, and the driver seem to work without a problem with my SE T610 mobile, however when I try to use the dial-up or file transfer features from my Nokia 770 Internet Tablet, the N770 tells me that it cannot connect.
On the laptop the driver comes up with the alert window telling that the N770 is connecting, but after that nothing happens.
Another thing is that although the N770 is paired with the laptop, it is not shown as the T610 is and the driver do not see it as a device that offers any services.
With the factory Toshiba driver I could at least use it for file transfer (although the paired device was not shown there either...). Any ideas?
Old 02-28-2006, 16:52   #94 (permalink)
Member: 161522
HP Bluetooth
Hey Dan,
Hope I can help. I currently own an HP DV1000 Laptop. My hp bluetooth headphones work with Software: ANYCOM Blue-USB-130 4.0.12800. PM me your email and I'll send them to you if you can't find them here. They should be around here for download somewhere. Currently I have:
Cambridge Silicon Radio
Firmware Revision: Version 802/1.1
HCI Version Bluetooth HCI 1.1
HCI Revision: 0322
LMP Version: Bluetooth LMP 1.1
LMP Sub Version: 0322
These are the only drivers I have gotten to work with my Internal HP Bluetooth device. They work perfectly. I have upgraded before and my HP Bluetooth Headphones failed to create a connection to send the audio.
I have also tried to flash my Internal Bluetooth. No success. I think my bluetooth needs to be flashed before I can upgrade to the latest widcomm drivers.
Someone, anyone, I've asked tons of times. Can anyone tell me if mine is flashable?????? Any help would be greatly appreciated.
Dan, let me know if you need any help. I know these work. Hope that helps.
Regards ,
Bmex63
Originally Posted by tdanro
Hi all,
I have the following BT devices:
Broadcom 2045 Bluetooth 2.0 USB Device (ver. 2.1.39.10, HCI 2.0 -200A and LMP 2.0 - 4127
MSI MS-6967 (ver. 525, HCI 1.1-020D, LMP 1.1-020D)
Bluetooh by HP (ver. 1393, HCI 1.1-0571, LMP 1.1-0571)
and the Widcomm Bluetooth Software ver. 5.0.1.1200
Trying to use some Bluetooth Stereo headphones (Audio-Mate Bluetooth Stereo Headset ) they works perfect with the Broadcom dongle, but not with the integrated Bluetooth by HP nor with the MSI dongle.
They are any updates available to upgrade the internal device and/or the MSI dongle in order to support version1.2, meaning to be able to use the A2DP profile for the bluetooth stereo headphones?
Thanks in advance,
Dan
Old 03-01-2006, 14:09   #95 (permalink)
Member: 232657
I have toasted my "Bluetooth By HP" internat device
Hi,
In between I have succeeded upgrade the firmware with a modified GenericCSR.dfu file, but still cannot connect to the High Quality Audio headphones. Trying to make an upgrade with a Mitsumi firmware I think I have now toasted the interface...http://forum.gsmhosting.com/ubb/frown.gif
It show as PID 0000 VID 0000 and "Unknow device" in device manager...
Any help to retreive the interface are wellcome.
Thanks,
Dan
Old 04-11-2006, 22:26   #96 (permalink)
Member: 258524
Talking
Thanks again
The dongle worked great,but since it was last used,sp2 has been installed,and the license.dat problem appeared.Tried "the fix" from the
mavintec.com website involving forcing the dongle to use widcomm drivers,and that didnt work either.
So i downloaded the 111mb 5.0.1.1200 drivers (x32 and x64) are included
in this,and downloaded from kasonkas post in page5, the widcomm patcher v2 .zip.got rid of previous widcomm software,as well as registry entries ( probably did not need to do this),rebooted,installed the 1200 drivers, rebooted into safe mode,installed the version 2 patch,which patches 4 files, 2 in the program files/widcomm,and 2 in system32 folder,rebooted again,plugged dongle in and hey great it works.
So thanx to all you guys in the previous post,who id probably still be scratching my head, without youre input.
Old 05-10-2006, 17:46   #97 (permalink)
Member: 274232
Nokia 6310i Sync via Bluetooth
Hi,
My bluetooth setup hasn't been working since XP SP2 was installed several years ago. I found this thread and have updated my old Widcomm 1.3 software to this Broadcom 5.0.1.1200 set.
(I had first tried Widcomm 1.4.?.? and learnt how to make manually replace the XP driver with the correct CSR one, but had kept getting the license.dat problem!).
So, I finally have bluetooth working again thanks to this thread! (sort of....)
Now I can pair my 6310i with my Laptop correctly and it finds all the services on offer. I configure the COM1 on the mobile to connect to COM6 on the laptop.
However, when I go into Nokia PC Sync, and select bluetooth connection it asks me which COM port, I select COM6, and the phone then disconnects (if already connected - or connects, then disconnects if not already connected), and Nokia software then gives me a "Couldn't connect to device" error message.
I though that maybe I hadn't fully solved my bluetooth problems and that perhaps my device still wasn't working, however I have successfully beamed a contact from my phone as a business card, and it worked seamlessly.
Has anyone here got any advice to offer on making 1200 software work with Nokia PC Sync version 4.88 (this is the latest version that will work with the old 6310i)? I probably didn't get the settings correct somewhere in the bluetooth software (or maybe the Nokia software?)
Details:-
The bluetooth device is a internal Billionton (I think it is class 2) device, which came pre-installed inside my Rock Quaddra DTS laptop. It lists itself as a USB device in windows device manager. I have a sliding switch on the laptop to enable/disable the bluetooth device.
{edited to add the following detail}
I downloaded the software from rapidshare.de (from thread posting:87 - on page:6)
I patched it using the orignal patch (from thread posting:12 - on page:1)
I also manually changed the svcpack.ini file (using text from posting:19 - on page:2)
But with correction of that inserted text on the last line from "1" to "5" (from posting:41 - on page:3)
I have read the whole tread several times.
{end of edit}
Thanks in advance.
Mike
Old 06-13-2006, 07:58   #98 (permalink)
Member: 293029
Hi
My dongle is still on the way and I guess I have succesfully installed the widcom 1200 driver and the patcher on my Dell inspiron E1505 laptop.
My question is does dongle works with Sony Ericson Z250a mobile phone?
Thanks.
Old 08-13-2006, 10:14   #99 (permalink)
Member: 321990
i can't able to download from megaupload site. is there any pass to download free
Old 04-29-2007, 11:58   #100 (permalink)
Member: 497923
Hi,
Has anyone been able to get "bluetooth by hp" with HCI 1.1 and LMP 1.1 (the firmware seams to be CSR version 802) to work with Steare headset profile?
I have installed the widcomm stack 5.0.1.1200 and it seams to have the feature support but it seams I need to upgrade firmware or something on my bluetooth device.
Is it even possible to upgrade the bluetooth device?
/Hanz
Old 05-10-2007, 00:00   #101 (permalink)
Member: 504334
Hi folks I'm new here and looking for some help. I have widcomm 5.0.1.1200 installed and working fine on Win XP SP2 with a CSR dongle. However I have now installed Vista as a dual boot system, I have installed Widcomm but on vista just get blue / red icon the dongle no longer flashes at all. (Before installing Widcomm it flashed like hell on the Microsoft drivers but I can never get them to work properly)
Any ideas on how to get this working on Vista??
Old 09-06-2008, 13:33   #102 (permalink)
Member: 803865
i need solutin for nokia 1200,1208,1650
Old 09-06-2008, 13:36   #103 (permalink)
Member: 803865
i need solution for contact service problem of nokia 1200,1208,1650.ply reply imediately
[IMG] code is Off
Widcomm 5.0.1.1400 adisor19 Bluetooth-Software 98 05-15-2008 15:28
Widcomm 5.0.1.802 adisor19 Bluetooth-Software 121 05-24-2007 19:52
Widcomm 5.0.1.801 luckyknight Bluetooth-Software 120 04-07-2007 13:12
Widcomm 5.0.1.802 + Vaio Integrated Bluetooth - Success! ro76 Bluetooth-Software 6 02-11-2006 22:45
SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. spd303 Bluetooth-Software 0 11-21-2005 21:12
Page generated in 0.28710 seconds with 10 queries
