02-27-2006, 16:27 | #91 (permalink) |
Junior Member Join Date: Feb 2006
Member: 237850 Status: Offline Thanks Meter: 0 | I used the 5.0.1.1200 drivers with the Widcomm_pather_v2.zip posted here. But the installation didn't go as smooth as expected. When i patched, restarted and plugged the dongle in, windows always intalled the microsoft drivers for it and the widcomm control panel couldn't see the dongle. So i removed the microsoft drivers before plugging it in to make it work. Thanks again |
02-28-2006, 09:22 | #93 (permalink) | |
Member: 237675 Status: Offline Thanks Meter: 0 | Quote:
I have the same Dell environment, and the driver seem to work without a problem with my SE T610 mobile, however when I try to use the dial-up or file transfer features from my Nokia 770 Internet Tablet, the N770 tells me that it cannot connect. On the laptop the driver comes up with the alert window telling that the N770 is connecting, but after that nothing happens. Another thing is that although the N770 is paired with the laptop, it is not shown as the T610 is and the driver do not see it as a device that offers any services. With the factory Toshiba driver I could at least use it for file transfer (although the paired device was not shown there either...). Any ideas? | |
02-28-2006, 16:52 | #94 (permalink) | |
Junior Member Join Date: Jul 2005
Member: 161522 Status: Offline Thanks Meter: 0 | HP Bluetooth Hey Dan, Hope I can help. I currently own an HP DV1000 Laptop. My hp bluetooth headphones work with Software: ANYCOM Blue-USB-130 4.0.12800. PM me your email and I'll send them to you if you can't find them here. They should be around here for download somewhere. Currently I have: Cambridge Silicon Radio Firmware Revision: Version 802/1.1 HCI Version Bluetooth HCI 1.1 HCI Revision: 0322 LMP Version: Bluetooth LMP 1.1 LMP Sub Version: 0322 These are the only drivers I have gotten to work with my Internal HP Bluetooth device. They work perfectly. I have upgraded before and my HP Bluetooth Headphones failed to create a connection to send the audio. I have also tried to flash my Internal Bluetooth. No success. I think my bluetooth needs to be flashed before I can upgrade to the latest widcomm drivers. Someone, anyone, I've asked tons of times. Can anyone tell me if mine is flashable?????? Any help would be greatly appreciated. Dan, let me know if you need any help. I know these work. Hope that helps. Regards , Bmex63 Quote:
03-01-2006, 14:09 | #95 (permalink) |
Member: 232657 Status: Offline Thanks Meter: 0 | I have toasted my "Bluetooth By HP" internat device Hi, In between I have succeeded upgrade the firmware with a modified GenericCSR.dfu file, but still cannot connect to the High Quality Audio headphones. Trying to make an upgrade with a Mitsumi firmware I think I have now toasted the interface...http://forum.gsmhosting.com/ubb/frown.gif It show as PID 0000 VID 0000 and "Unknow device" in device manager... Any help to retreive the interface are wellcome. Thanks, Dan |
04-11-2006, 22:26 | #96 (permalink) | |
Junior Member Join Date: Apr 2006
Member: 258524 Status: Offline Thanks Meter: 0 | Quote:
mavintec.com website involving forcing the dongle to use widcomm drivers,and that didnt work either. So i downloaded the 111mb 5.0.1.1200 drivers (x32 and x64) are included in this,and downloaded from kasonkas post in page5, the widcomm patcher v2 .zip.got rid of previous widcomm software,as well as registry entries ( probably did not need to do this),rebooted,installed the 1200 drivers, rebooted into safe mode,installed the version 2 patch,which patches 4 files, 2 in the program files/widcomm,and 2 in system32 folder,rebooted again,plugged dongle in and hey great it works. So thanx to all you guys in the previous post,who id probably still be scratching my head, without youre input. | |
05-10-2006, 17:46 | #97 (permalink) |
Junior Member Join Date: May 2006
Member: 274232 Status: Offline Thanks Meter: 0 | Nokia 6310i Sync via Bluetooth Hi, My bluetooth setup hasn't been working since XP SP2 was installed several years ago. I found this thread and have updated my old Widcomm 1.3 software to this Broadcom 5.0.1.1200 set. (I had first tried Widcomm 1.4.?.? and learnt how to make manually replace the XP driver with the correct CSR one, but had kept getting the license.dat problem!). So, I finally have bluetooth working again thanks to this thread! (sort of....) Now I can pair my 6310i with my Laptop correctly and it finds all the services on offer. I configure the COM1 on the mobile to connect to COM6 on the laptop. However, when I go into Nokia PC Sync, and select bluetooth connection it asks me which COM port, I select COM6, and the phone then disconnects (if already connected - or connects, then disconnects if not already connected), and Nokia software then gives me a "Couldn't connect to device" error message. I though that maybe I hadn't fully solved my bluetooth problems and that perhaps my device still wasn't working, however I have successfully beamed a contact from my phone as a business card, and it worked seamlessly. Has anyone here got any advice to offer on making 1200 software work with Nokia PC Sync version 4.88 (this is the latest version that will work with the old 6310i)? I probably didn't get the settings correct somewhere in the bluetooth software (or maybe the Nokia software?) Details:- The bluetooth device is a internal Billionton (I think it is class 2) device, which came pre-installed inside my Rock Quaddra DTS laptop. It lists itself as a USB device in windows device manager. I have a sliding switch on the laptop to enable/disable the bluetooth device. {edited to add the following detail} I downloaded the software from rapidshare.de (from thread posting:87 - on page:6) I patched it using the orignal patch (from thread posting:12 - on page:1) I also manually changed the svcpack.ini file (using text from posting:19 - on page:2) But with correction of that inserted text on the last line from "1" to "5" (from posting:41 - on page:3) I have read the whole tread several times. {end of edit} Thanks in advance. Mike Last edited by mdoragh; 05-10-2006 at 18:09. |
06-13-2006, 07:58 | #98 (permalink) | |
Junior Member Join Date: Jun 2006
Member: 293029 Status: Offline Thanks Meter: 0 | Quote:
My dongle is still on the way and I guess I have succesfully installed the widcom 1200 driver and the patcher on my Dell inspiron E1505 laptop. My question is does dongle works with Sony Ericson Z250a mobile phone? Thanks. | |
04-29-2007, 11:58 | #100 (permalink) |
Junior Member Join Date: Apr 2007
Member: 497923 Status: Offline Thanks Meter: 0 | Hi, Has anyone been able to get "bluetooth by hp" with HCI 1.1 and LMP 1.1 (the firmware seams to be CSR version 802) to work with Steare headset profile? I have installed the widcomm stack 5.0.1.1200 and it seams to have the feature support but it seams I need to upgrade firmware or something on my bluetooth device. Is it even possible to upgrade the bluetooth device? /Hanz |
05-10-2007, 00:00 | #101 (permalink) |
Junior Member Join Date: May 2007
Member: 504334 Status: Offline Thanks Meter: 0 | Hi folks I'm new here and looking for some help. I have widcomm 5.0.1.1200 installed and working fine on Win XP SP2 with a CSR dongle. However I have now installed Vista as a dual boot system, I have installed Widcomm but on vista just get blue / red icon the dongle no longer flashes at all. (Before installing Widcomm it flashed like hell on the Microsoft drivers but I can never get them to work properly) Any ideas on how to get this working on Vista?? |
Widcomm 5.0.1.1400 | adisor19 | Bluetooth-Software | 98 | 05-15-2008 15:28 |
Widcomm 5.0.1.802 | adisor19 | Bluetooth-Software | 121 | 05-24-2007 19:52 |
Widcomm 5.0.1.801 | luckyknight | Bluetooth-Software | 120 | 04-07-2007 13:12 |
Widcomm 5.0.1.802 + Vaio Integrated Bluetooth - Success! | ro76 | Bluetooth-Software | 6 | 02-11-2006 22:45 |
SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. | spd303 | Bluetooth-Software | 0 | 11-21-2005 21:12 |
