05-24-2004, 17:07 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Netherlands Age: 43
Member: 60442 Status: Offline Thanks Meter: 6 | 6600 alive but ufs-3 can't read or flash phone? i have here a 6600 with contact the retailer i solved this problem but i put the wrong ppm in the phone. i tried to flash the other ppm into the phone but the phone makes no connection with the box anymore. it would't read the phone or flash the phone and i can't also put it in local or test mode anymore someone an idea how to solve this problem? peter |
05-25-2004, 22:45 | #4 (permalink) |
Registered User Join Date: May 2004 Location: Lebanon Age: 44
Member: 65294 Status: Offline Thanks Meter: 11 | when u plug the cable to ur 6600 and when ur ufs flasher is opened and u r on WD2 section...do the 6600 have the word nokia on it's screen ??? waitting |
05-27-2004, 22:42 | #8 (permalink) |
Member: 60442 Status: Offline Thanks Meter: 6 | faithless gsm: when i connected the cable the phone didn't go to local mode by itself. so when i started to flash it was searching for the operating mode and could not detect it. The next time i pressed start and hit the on button of the phone a few times and that worked. so i ment by manually myself But thanks again. Regards peter |
05-28-2004, 01:34 | #9 (permalink) |
Member: 65294 Status: Offline Thanks Meter: 11 | ahha i see then what u have to do is find this file ccserasepmm and flash it using the manual way u said above then write pm then format user area then flash ur phone normally with the ppm u like hope it work regards... |
KF300 can't read or write flash | dust66 | FuriousGold | 2 | 07-29-2009 15:39 |
W890 - Can't read info or flash phone | Henrik Liss | Universalbox | 4 | 05-09-2009 16:41 |
my Tornado Ufs-3 can't detect any phone | kfkevin | UFS2 + UFS3-Tornadoflasher | 0 | 01-28-2009 16:33 |
Dead SL45 alive, but one problem can't be solved | Chuk | x1x to x45/x50 | 7 | 11-04-2002 10:50 |
