03-05-2004, 10:08 | #1 (permalink) |
Freak Poster Join Date: Feb 2003 Age: 42
Member: 22109 Status: Offline Thanks Meter: 0 | Not able to use rpl-file! Please help! @legija @ufs2flasher I just got an RPL-file which I need to repair Imei-area in a Nokia 6200. Is has been made by ask-file and the converted to rpl-file. When I try to use the write UEM - SL function the program respons by: Ambiguous ASIC TYPE og non GSM-product. Would you like to proceed? Yes or no? What is that? In display window it says: IMEI: ??????-??-??????-?, ASIC: 2 File Info: IMEI=351461500***** CHECKSUM=-2085 No Data2 in File ASIC Type Mismatch, Process Aborted No SIM_PROG_DATA in File What to do? I haven’t tried saying yes. As I understand you only have one try at flashing the UEM chip! Am I right? Is it perhaps because the rpl-file was calculated as ASIC 5 instead of ASIC 2 (Nokia 6200 is Asic 2)??????? Any help would be greatly appreciated Thanks in advance best regards Martin Last edited by m_dige; 03-06-2004 at 22:01. |
10-22-2004, 13:03 | #5 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 45
Member: 54419 Status: Offline Thanks Meter: 0 | Ok who is doing your RPL calculations for you. maybe thay are not converting it correctly remember griffin server RPL,s are not compatable with UFSX series flashers so you might have needed to covert them to this platform as well and the convertor needs some tweaking to make it work correctly |
10-22-2004, 14:12 | #6 (permalink) |
No Life Poster Join Date: Mar 2003 Location: One step before you ;) Age: 42
Member: 23695 Status: Offline Sonork: 100.64383 Thanks Meter: 12 | The griffin server rpl's not same as original,the severs rpl dont have precalculated simlock data,only data1 and data2 section,and the ufsx series not directly calculated the simlock data,only using map files.Griffin rpl's work with ONLY griffin box |
Not able to make rpl backup with mx-key 5.0 | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 09-25-2009 17:12 |
To Admin and AboAli, I am not able to upload any file since day one | sniper007 | Board, Server and Login Problems/Support | 2 | 08-03-2009 16:07 |
@ [Boban]&[Dejan Kaljevic] - HELP! Reseller Not Able To Provide Key File To Customer! | Mr.Ultimate | BB5 Box by D.K. | 12 | 12-05-2008 09:55 |
not able to use furious box >>>>> | hiteshhitesh | FuriousGold | 2 | 10-31-2007 10:16 |
Not able to use 2.085 after update? | aboveconnection | Griffin | 6 | 09-14-2004 17:30 |
