05-20-2007, 16:49 | #1 (permalink) |
No Life Poster Join Date: May 2006
Member: 276432 Status: Offline Thanks Meter: 65 | Help Me My Tornado Ufs-3 When Itry To install HWK_Suite_Setup_v2.0.5.exe PC Suhtdown What is the problem i try to install another system but still the problem and i install driver corrctly and the device is run |
The Following User Says Thank You to dvdaio For This Useful Post: |
05-20-2007, 16:54 | #2 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: VietNam Age: 43
Member: 378053 Status: Offline Thanks Meter: 98 | Quote:
Now can solve this problem.Before you install this file you must right click on this file then choose properties-->compatibility-->Run this program... select Windows NT 4.0 (Service Pack 5) click ok.Now you can isntall dont care your PC shutdown. as same for 2.05.1 and other.Goodluck | |
05-20-2007, 16:55 | #3 (permalink) | |
No Life Poster Join Date: May 2005 Location: malaysia Age: 40
Member: 149041 Status: Offline Sonork: 100.114578 Thanks Meter: 61 | Quote:
tested it work fine | |
install HWK_Suite_Setup_v2.0.5.exe | Mi16v | HWK | 6 | 10-21-2007 23:14 |
Cant install HWK_Suite_Setup_v2.0.5.exe | dannyogolo | HWK | 3 | 10-17-2007 03:52 |
problem with installing HWK_Suite_Setup_v2.0.5.exe | Winner58 | HWK | 39 | 08-31-2007 14:07 |
HWK_Suite_Setup_v2.0.5.exe | Dilip_Nath | UFS2 + UFS3-Tornadoflasher | 2 | 08-21-2007 09:21 |
PROBLEM SOLVED WHEN HWK install 2.0.5 -> PC turn off | ..::: Naveed :::.. | HWK | 10 | 06-28-2007 12:01 |
