11-05-2004, 01:32 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: spain Age: 46
Member: 79485 Status: Offline Thanks Meter: 47 | mezzed up with UEM change thanks to everybody |
11-05-2004, 21:50 | #3 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | Does the phone can worke with this other IMEI Without change It to the original one ??? ie : When I write an *.rpl file to my phone (with dumaged IMEI ) , Does the phone will worke well ??? |
11-05-2004, 21:57 | #4 (permalink) |
Member: 79485 Status: Offline Thanks Meter: 47 | ok I dontīt think I must pay for a rpl file calculated from an ask-file, what is the function of actgsm pm editor then? So today Iīve had to write an uem with griffin cause the tornado didnīt allowed rpl writting, How can I write rpl with ufs? |
11-06-2004, 00:36 | #5 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Tallinn
Member: 40082 Status: Offline Thanks Meter: 3 | @bamor2000 yes, you can write any rpl (imei) file to the phone and it will work, but before you have to change UEM IC. @petermov ufs writes rpl files without problems. just try it correctly. you don't have to pay for the rpl file if you have damaged FLASH IC, you can make rpl file for flash IC by yourself, but if UEM IC is damaged you have to pay to buy rpl with the same imei as you have. no free solution 100 % (none of actgsm pd editors, etc... can do it) |
11-06-2004, 22:37 | #9 (permalink) | |
Member: 27291 Status: Offline Thanks Meter: 81 | Quote:
Excuse me again ! my last question : How to change this UEM IC ? ( hard or soft )? Best regards | |
08-02-2005, 14:32 | #13 (permalink) |
No Life Poster Join Date: Jul 2001 Location: md Age: 25
Member: 5379 Status: Offline Thanks Meter: 0 | @kibsoft : you don't have to pay for the rpl file if you have damaged FLASH IC, you can make rpl file for flash IC by yourself, but if UEM IC is damaged you have to pay to buy rpl with the same imei as you have. no free solution 100 % (none of actgsm pd editors, etc... can do it) is it true if we have damaged flash ic, then we can make the flash ic rpl by ourself ?? how can we do that ?? regards |
7610 after 1 miniut close with uem changed | MELME | Nokia Hardware & Hardware Repair | 4 | 04-05-2005 13:04 |
Problems with Nokia 7250 after UEM changed | GSMFRAN | Nokia Digital Core Technology 4 ( DCT-4 ) | 20 | 03-09-2005 11:11 |
DCT4/WD2/TIKU IMEI/ESN CHANGE without UEM change | asteraky | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 05-21-2004 11:29 |
This guy claims that he's soft can change imei in DCT4 with out change of UEM!!! | Gsmhq | Nokia Multimedia | 2 | 10-25-2003 10:21 |
