02-26-2005, 21:24 | #1 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 90576 Status: Offline Thanks Meter: 1 | nokia 1100 contact service A customer brought 2 nokia 1100 phones showing contact service.. any idea on how to solve this problem with tornado flasher? I tried some ui settings, but it wasn't succesful. Then i tried to flash one of them but i got an error when erasing was being perfomed and the phone is dead right now. Any clue? i need to fix the dead one and the other one showing contact service. Any help would be greatly appreciated. Regards. |
02-27-2005, 06:07 | #2 (permalink) |
Junior Member Join Date: Feb 2005 Location: Dhaka Age: 44
Member: 116490 Status: Offline Thanks Meter: 1 | What kind of error u r facing? if it is erasing process failed, then reflow the UEM with hotgun and try to flash again. Otherwise erase the whole flash and flash the mobile with mcu,ppm and pm files. Thanks ---shaybal |
02-28-2005, 16:31 | #4 (permalink) | |
Member: 90576 Status: Offline Thanks Meter: 1 | Quote:
Any pm file from 1100b(rh-36) will work?, because i did not backed up original pm.. I've always had this doubt about pm.. please let me know if any pm would work.. in case it won't, please advise how to get the right the pm to write to phone . Thank you Best Regards. | |
02-28-2005, 16:34 | #5 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: Prijepolje-Durmitor, Serbia And Montenegro Age: 46
Member: 19987 Status: Offline Thanks Meter: 27 | Quote:
Regards Mackie | |
03-02-2005, 08:52 | #7 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: India Age: 39
Member: 20691 Status: Offline Thanks Meter: 20 | Quote:
Bro... Just don't keep on asking.. do something practically by your self also ... Read the posts properly, try what is being wrote... 1.) Erase Full Flash 2.) Flash the phone again with MCU + PPM + PM 3.) Simlock + Full Factory Try these steps ... and post the errors here ... Regards, Tanvir ! www.tanuelectronics.com | |
03-10-2005, 15:53 | #8 (permalink) |
Junior Member Join Date: Dec 2004 Location: Barcelona, Spain Age: 52
Member: 99876 Status: Offline Thanks Meter: 0 | I have a similar issue with a 3140 (DCT3) showing 'contact service' and have tried all of the above and more, without success. I notice that the IMEI net and the IMEI osn are different, and both are incorrect. I have tried to rebuild IMEI but this appears to complete without any changes taking place. Any elp appreciated. |
03-10-2005, 23:11 | #13 (permalink) |
Freak Poster Join Date: May 2004
Member: 64341 Status: Offline Thanks Meter: 1 | if u have a 3410 that says contact service and u have written the mcu and ppm zones,made ui defaults and u still have contact service just copy another phones pm if u do not have one. write this pm into the phone and what u will see a phone that only shows battery strenth signal.do ui defaults . then use Eeprom tool by B-phreaks v3.1(it a freeware so just look around for it) to repair the phone otherwise ull get a crazy a phone. it this solution fails u, then its either u did not do it well or it not software problem. pm flashing for 3410 normally hangs for a second at ab out 60% so do not think the process has failed/hanged and give up. regards |
04-26-2005, 01:46 | #14 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Dublin Age: 44
Member: 100436 Status: Offline Thanks Meter: 57 | Quote:
I'll post back if it get it sorted, it might be barried | |
nokia 1100 contact service | sphameed | Nokia Hardware & Hardware Repair | 21 | 05-10-2010 13:13 |
nokia 1100 contact servic | saqi160 | Nokia Hardware & Hardware Repair | 12 | 03-14-2010 16:53 |
Need Help on Nokia 1100 Contact Service | karkitz | Nokia Hardware & Hardware Repair | 9 | 09-18-2008 03:50 |
nokia 1100 contact service | naveed malik | Nokia Hardware & Hardware Repair | 7 | 08-05-2007 22:20 |
nokia 1100 contact service | maplegsm | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 07-19-2007 14:14 |
