12-03-2005, 17:50 | #1 (permalink) |
Junior Member Join Date: Sep 2003
Member: 38207 Status: Offline Thanks Meter: 0 | Nokia 1600 connection problem Ive got brand new Nokia 1600 form Tmobile UK. Im using Tornado without HWK and here's the problem: When I use Dctx_ufs v1.3k and press Check Ive got: 1st Boot Ok, DCT4, UPP: 2201 Rebooting Mobile and press Info: MCU Sw: V 3.07 05-08-05 RH-64 (c) NMP N1600 PPM Sw: V 3.07 05-08-05 RH-64 (c) NMP N1600 AE Prd.Cd: 0529231 Bpr.Cd: 0520754 Pro.Sn: PGJ848174 HW : 0502 PCI : UEM : 1314 UPP : 8705 RFIC : 0500 DSP : P05w06.v20 LCD : SEID:S31va0 IMEI : xxxxxx-xx-xxxxxx-x SLconf: 234-30-00000000000 SLprof: 800000000000000-2 SLvar : 00003579460043229700 SLaux : 00020000 But I cant flash it, because this Dctx doesnt support this phone. When I connect the 2600 Nokia on the same cable everything is ok, it is detected and I can flash it, so I dont think cable is wrong. But the problem is when I want to use newer program - when Im using UFS_DCTxBB5 v1.4c HWK and DctxBB5_14b-test7 HWK I cant connect, phone cant be detected. When I press Check momentally Ive got: 1st Boot Err: Bad Resp UFSx 1st Boot Err: Bad Resp UFSx Rebooting Mobile What to do ? I dont think is the cable problem, because on previous versions of DCTx phone is normally detected, and here it isnt. But maybe I am wrong and I need to do somethingn with cables. If somebody has experienced the same problem as I do please let me know and help to find solution. Or maybe there is another, newer than v 1,3k, version of DCTx , which isnt for HWK and support this model ? |
12-03-2005, 23:40 | #2 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | Quote:
12-05-2005, 01:08 | #4 (permalink) |
Member: 38207 Status: Offline Thanks Meter: 0 | OK is done, I reinstall everything and install only newest version od DCTx and program asked me if I want to upgrade my firmware, and as I have original I press YES, and now Ive got v.2.6 and everything is working perfectly. |
Nokia 1600 Keypad Problem | Amarbir | Nokia Hardware & Hardware Repair | 18 | 02-28-2014 07:15 |
nokia 1600 light problem | firrozkhan_00 | Nokia Hardware & Hardware Repair | 6 | 09-20-2010 08:58 |
Nokia 1600 light problem | Métal_gsm | Nokia Hardware & Hardware Repair | 1 | 12-02-2006 04:47 |
Nokia 1600 Led Problem | thechatfriend | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 05-16-2006 16:47 |
