Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
04-20-2000, 11:35 | #4 (permalink) |
Junior Member Join Date: Apr 2000
Member: 1225 Status: Offline Thanks Meter: 0 | tcd128/b4 series ---------------- #0D00 - checksumm #0D22 - Lock 1 00-off; 01-ON #0D2E - Lock 2 #0D3A - Lock 3 #0D46 - Lock 4 decrease this byte to 00 and decrease checksumm (for example: 0C to 0B etc...) !!! #0D18 - CODE 1 #0D26 - CODE 2 #0D32 - CODE 3 #0D3E - CODE 4 PCK (51,97,01,92 = in phone enter 15791029) Don't forget to decrase Checksum BTW: does someone knows the pinout for this phone? Regards, CyberPhreack |
04-20-2000, 23:10 | #5 (permalink) |
Freak Poster Join Date: Dec 1999 Location: Bulgaria
Member: 838 Status: Offline Thanks Meter: 0 | OK Man today is your Birthday change this is info what you need 00C0-0132-If you change any values and not correct checksum -blocked permanently for version 00DE- if this value is 01 change with -1 (example 01 change to 00) 00F6- if this value is 01 change with -1 (example 01 change to 00) 00C0- change sheksum to -2 (example 25 change to 23) |
04-20-2000, 23:13 | #6 (permalink) |
Member: 838 Status: Offline Thanks Meter: 0 | 00C0-0132-If you change any values and not correct checksum -blocked permanently for version 00DE- if this value is 01 change with -1 (example 01 change to 00) 00F6- if this value is 01 change with -1 (example 01 change to 00) 00C0- change sheksum to -2 (example 25 change to 23) |
04-23-2000, 11:04 | #9 (permalink) |
Junior Member Join Date: Apr 2000 Location: malta
Member: 1245 Status: Offline Thanks Meter: 0 | have tried serbian hacker v2. with no success the phone says permanently blocked. now what do i do. please help. the above solutions do not work. on this eeprom dump. thanks. |
Savvy TCD128/BD language | CPG | Philips | 2 | 12-02-2002 11:41 |
tcd128/bd flash problem | s4sajii | Philips | 13 | 01-27-2002 20:50 |
Savvy TCD128/BD Cable Solution ?? | AboAli | Philips | 3 | 08-29-2001 16:14 |
savvy tcd128/BD | stefangrigorov | Various | 9 | 09-19-2000 10:50 |
Philips Savvy tcd128/BY and tcd128/S9 | Comic | Various | 2 | 08-10-2000 22:52 |
