Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
05-16-2000, 01:53 | #1 (permalink) |
No Life Poster Join Date: Jun 1999 Location: Germany
Member: 233 Status: Offline Thanks Meter: 36 | Here are Solution for Savvy 128/H4 and H9 I'am search overall, and found no Infos abaut H9 Version. I tested self and found this solution: Read Eeprom an edit your read, but make a copy to rescue your Phone, when you it destroy. Check the Adresses 0d23, 0d2b, 0d46, 0d4e, and change only value 01 to 00, is a adress not 01, do not change this adress !!!!!!. Now you must correkt the checksum at adress 0d00: Check how many adresses you have change from 01 to 00 ( Normaly 2 Adresses ) and reduce the value from adress 0d00 at this number. eg: You have changes 2 adresses you must reduce with - 2 eg: 8f - 2 = 8d. go the checksum to zero try this way: 02, 01, 00, ff, fe, fd Have tested at 20 Savvys from German D2 Network, TCD128/H4 and TCD128/H9 version. Enjoy Jan |
***Here Are Descriptions of NsPro Error Messages And Solutions For That Errors*** | NADEEM GONDAL | NSPRO | 10 | 01-12-2010 06:28 |
looking for savvy 128 h4 flash+eeprom | -=ELF=- | Philips | 1 | 05-08-2003 00:13 |
Savvy 128/H4 Call Cust.Service | Format1 | Philips | 9 | 02-15-2001 21:26 |
Solution for Savvy 128/H9 Call Cust. Service | MaRiN | Philips | 14 | 12-24-2000 11:42 |
Need flash file for Savvy 128/H4 | Haupti | Various | 0 | 10-26-2000 19:28 |
